Rotary Super Sport with AS984
Deggsie
I now have this little Rotary Super Sport ticking away after spending weeks putting the hair spring to rights. Hair springs are my nemesis!!!! The crystal has a crack in it and I’d like to replace it, however the crystal lift I have will not compress the diameter as there is a draft angle on the crystal. Therefore the tendency, however hard I try, is for the claws to slide up the side of the outside diameter. Any ideas please, or can I just push out by hand and fiddle the new one back in?
Cheers. Yes I think I’ve got a couple of those tools. Mind you, mine are slightly fatter than yours. I think it’ll still work though [emoji6]
I was reluctant to go higher with the dome in case it looks out of proportion.
Cheers, Deggsie
