Questions, Valjoux
                        1- I read CDG Rotor quite offen, what dose CDG stand for?
                         2- I got a 7750 movement, marked VAL,  dose that mean it is a genuine swiss valjoux?
                         3- When did valjoux start producin in Asia.
Edited by Nucejoe
Sorry for the messed up format.
1. CDG (Cote De Geneve) is the striped finish on the rotor.
2. Some might have been stamped with VAL before it was integrated in the Swatch Group (ETA)
3. Clones are made in Asia and some spare parts. Otherwise the history is in this link.
https://www.watch-wiki.net/index.php?title=Valjoux_7750
Thank you HSL, Informative as usual, so mine signed VAL 7750, was produced prior to integration with swatch, therefor, genuine. I red ( on the net) the genuine ones have five ball bearing rotor, mine got seven, what is your thought on that?  Thanks in advance.
The most of the 7750 rotors I'we seen has just 5 balls from the factory, guess it's the minimum amount of balls that will make it last for a certain time.(There has to be an aftermarket too.) Then there are some third-party bearings with 7 balls in them, one could say they have upgraded it a bit.
I am in no sence involved in Selling these so I put this link here in an informative sence ;)
https://www.mps-watch.com/en/products/bearings/prodige.html
  • Sad 1
41 minutes ago, nickelsilver said:
The old Valjoux 7750 rotor has 7 balls from what I've seen. These have a pressed/riveted bearing, unlike the modern version with the bayonet fitting.
Thank you @nickelsilver , makes perfect sense, I bought just the movement, used, about twenty years ago, it must have worked in a watch like ten to fifteen years, seemed to me, aftermarket bearings are unlikely to have had a market then, good enough to justify costs of a new design/ production, thence, seven ball bearings could have come in old versions, now we know it did. Regards
So it seems you have an untainted Valjoux in you Collection, so nucejoe now we need some movementporn,pictures!
Yes sir, it's just the movement, it came in a Lot of 150 movements, dirty now and in pieces, ran good in my view, will clean post pix in this here thread and inform you all. Regards.
6 minutes ago, Nucejoe said:
Hi @HSL  , The valjoux movement is on the bench, received penetrating oil before final strip down.dirty dirty.
I need your guidance for useful presentation of the pictorial. Joe
lol for a while I thought we were in the red-light district with all the Dirty talk..
I'm not sure of what you mean, I'm extremely photogenic but it might not help here.. :)
I have no idea how to make this presentation. Sbow all parts?
    • I still need to see the complete movement as there are many types of Elgin movements. The part that you are holding is called a snail.
    • Just a quick update on my T17. I just finished the service and, boy, was this nerve-wrecking.... I bent the hairspring a few times. Stupid accidents. Once it was beyond repair and I had to get a donor movement. The replacement hairspring turned out to be a few millimeters shorter and therefore the watch was running 6min too fast even when the regulator was set to the slowest position. So I needed to get timing washers (see another post here: https://www.watchrepairtalk.com/topic/25505-30t2-adjustment-of-timing-washers/?do=findComment&comment=248100).  After all, I'm now, getting a 310° amplitude (fully wound, dial up, lift angle 54°). About 250 in vertical positions. Quite a drop, but apparently not too abnormal for a 90-year-old watch with a slow beat rate (18000bph) and rather heavy balance wheel. After 24h I still get 280 (horizontal) and 220 (vertical). And now the highlight:  66h of power reserve! You may remember that I posted that I used a slightly weaker, but also slightly longer mainspring than prescribed. See my comments above.  I used GR 3937 (instead of GR 3632). So I recommend this mainspring and ticker oils (9020 on escape wheel and HP1300 on the rest of the train).
    • OK! I was able to get a nice set of timing washers from ebay! And they worked really well. I needed to slow down the movement by about 6min and I put four (=two pairs) of 3-minute washers (rated for the the size of the movement) and it did pretty much exactly that. On one pair of screws, there were already washers. So I added a second washer on those screws. Maybe not ideal, but it doesn't cause any problems. Poise is ok.. not perfect.. but I had so many issues with the watch that I decided to accept it. It's a 90-year-old watch. Delta is around 40 seconds.
    • I think it is friction fit, there are tools to remove them, cheaper versions are available. You could try adapting some pliers, see my crap drawing.  The pushers are available in various sizes, you could measure once the tube is removed.
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
