Eta 7750 reset issues
Hi!
I am having problems resetting the chronograph after servicing my IWC porsche design. This is far from my first rodeo on the 7750 and I consider myself quite competent with it.
The problem lies in the reset operating lever. The pusher stem pushes too low on the reset lever and instead of resetting the chronograph it just flexes inwards. If I use pegwood or a movement holder, it resets correctly because it pushes higher up on the operating lever.
I was thinking I should either bend the operating lever slightly outwards so it would hopefully overcome the flexing or loosen the cam jumper so it doesnt take as much force to reset. Any ideas and tips would be greatly appreciated if anyone has had a similar issue before, thanks!
Best regards,
AnttiVideo from Antti
Terve Antti!
As you can see from my photo the error is caused by an position error it seems your hammer is riding on top of the chronograph cam .
Somtimes after an service the assembled hammer isn't in the correct place you can check that throght pushing the other button twice.
2 hours ago, HSL said:
Terve Antti!
Moro!
I'm not quite sure what you mean. Reset works perfectly outside the case and doesnt require a lot of effort either. Ive attached a clearer picture.
What I mean when watching your original video video it seems like the hammer which makes the reset is lying above the Cam, thats why it doesn't reset and just flexes.
Aah ok! I checked and it is seated correctly  and if i push the operating lever with my (brass) tweezers it resets properly. I think I just got really unlucky and managed to find the only malfuctioning reset operating lever ever. Thanks for the idea!
I'm a bit of a movement nerd and just want to learn a bit of what movements are used in which watch, yours look like one I had in a watch I owned a couple of years ago, an IWC Flieger chronograph with a C.7922 which also is an derivate of the 7750.
  • 3 years later...
Hello
I have the same problem with my eta7750. How can I correct the position of the cam? I appreciate any tips. Thank you
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is. I've attached a lesson regarding mainsprings, focussing on the size and strength of the spring within the barrel, you might find helpful. Unfortunately it is a PDF converted from a PowerPoint presentation, but only a slide was lost that was originally a video of fitting a mainspring   Lesson 5 The mainspring.pdf
