Difference between AM and MM Tweezers?
LumeShot
Hi guys. Recently I've invested in Dumont tweezers, the #2, #3 and #5 from the "Dumostar series" and the #2 and #1 from the "Hi-Tech economy series", but now I'm looking into getting some quality brass tweezers as well.
I was looking through Horotec's line of brass tweezers but noticed that there were two types, the "AM" and "MM". I couldn't find information online about the difference between the two and which  job each type was purposed for. Could anyone explain the differences between "AM" and "MM" brass tweezers? Thank you!
If you look at the Guide to Watchmakers Tweezers on Esslinger they show as a style and show these marks on many different styles of tweezers.
https://blog.esslinger.com/guide-to-watchmakers-tweezers/
Now I am confused, so I went to a source and ask the question on what the MM and AM markings mean from Dumont Tools. I will post the reply when it comes in.
On 5/10/2019 at 4:48 AM, oldhippy said:
MM are Non-magnetic. AM are Anti magnetic.
I could not find information regarding non-magnetic vs anti-magnetic. However, since the tweezers are made of brass, I had assumed they would not be magnetic at all. Which left me wondering with the question in the original post.
Same! I was reading all over horotec for some type of distinction between MM and AM, but there was no actual explanation. Hope to hear from what Dumont has to say about it.
Ok, this is what I got from Dumont:
Hi,
Many thanks for your email. The AM or MM on the twezeers are the type of tweezers as you can see on our PDF brochures attached.
This is not meaning no magnetic or magnetic !!!
Tweezers AM that we produce are BRASS tweezers with a gold cover of 3 microns .
 Feel free to contact me if you have other questions.
Thanks to work with our tweezers.
Our family factory has 5 generations ( same family--- my husband was a Dumont son. ).
 Kind regards,
 Nicole Sgobero
Vice President
Now granted this is just one company. I am sure each one has different meanings for the "AM" and "MM" markings.
Edited by Charlie925
added notes.
2 hours ago, Charlie925 said:
If anyone would like the .pdf's she sent me. Send me a pm with an email address. they are quite large.
You can also attach them to a posting, no problem with that.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
