    • That’s a great watch! Sent from my iPhone using Tapatalk Pro
    • Hello everybody. I lived in Texas 51 years before moving “up north” to Oklahoma last year. One of my passions is fixing things - working on the house, appliances, cars, trucks, motorcycles, lawnmowers, and anything else that needs fixing and I’ve been good at it except when it comes to watches - what a humbling experience. Googling “broken set lever screw 6497” led me down a trail that led to this forum.   For watches: I like just about everything regardless of cost. I have a 1969 Datejust that my grandfather bought new (my watch addiction started there when I was little), and a 1966 Datejust I recently picked up, an Omega AT, a few Seikos, a Vostok, a couple Citizens, an old Bulova, a few Timexes, and a wristwatch-from-pocketwatch conversion with a genuine 6498 movement. Like many of y’all I’m sure, I’ve bought and sold a ton of watches since 1985 and haven’t slowed down.   The embarrassing screw-breaking watch is a Panerai look-alike with an ST36 Chinese copy of a 6497. It’s cheap but I figured it was good to learn on. Water was getting in, and the set lever screw was stuck so I broke it trying to get the stem out. Broke the two stuck movement mounting tab screws also, probably due to the water. Got a new ST36 and broke the same dang set lever screw trying to replace the stem. Can’t blame the water this time. Had no idea a tiny screwdriver could deliver enough torque to break screws. The price of education... I need to enroll in a course and stop red-necking this stuff.   I have plenty ST36 parts if y’all need any -except screws....   Great to be here,   Bobo         Sent from my iPhone using Tapatalk Pro
    • Hi William, Welcome to the forum. Have been to Elvis and Dolly parton show at Grand ole opry.  Carried out research work in the Atomic City.    Glad to have you here with us. Best wishes. Joe
    • To find out if the slot is in the right place, get a piece of wood wide enough to take the movement, use a 3/8th inch bolt and cut a slot in the end to take the suspention spring, drill a hole near the top of the wood and attach the bolt with a nut. hook the pendulum onto the suspention spring, attach the movement to the board where the crutch is at about the middle of the slot on the pendulum, if the movement is working? the clock should work, attach the hands and see if it is keeping time, which I doubt as I think the slot is way to low, anyway now you have this set up you can just move the movement UP or down till you find the right place for the slot. You do not need to cut the slot while trying to find the right place,  just drill a hole a 1/16th of an inch wider than the crutch, you may end up with a few holes however when about in the right place then cut the slot an 1/2 inch above and below the hole, you can fill to holes or just buy a new pendulum stick.
