Seiko crystal query
Hi guys
I've got a friends Seiko 7T62-0fd0 that needs a new crystal , on Cousins site they list 2 the 310p03hn02 which is obsolete and the 310po3hb0a which they have in stock , I have searched through the internet for reference on the codes but can't find out if the obsolete crystal has been succeeded by the in stock one or whether they are different?
The crystal in the watch has a gold ring on the actual crystal (doesn't come off) so if the replacement doesn't it's going to look a little odd i would imagine.
It's £20 plus vat etc etc and as we know Cousins won't take it back if its not right , so if anyone can advise as to whether it will be ok or not that would be most appreciated TIA Andy
Tne tension ring can be replaced and installed easy.
You may find crystal with ring in it hard to install, the tension ring jumps out if pressed.
I have got some Genuine seiko crystals, well I have got bunch of genuine most parts.
Give diameter and height, I will dig in my bag of tricks.
Regards
Regards
Many thanks for that it isn't actually a tension ring its actually attached to the glass which is flat mineral glass  with a polished inside edge diameter is 310 and thickness is 1.58 , could use a normal mineral crystal probably but it wouldn't have the gold ring , so wouldn't really look right
  • 6 months later...
11 minutes ago, RAT said:
310P03HB0A is the correct part number, also 310P03HN02 is NOT obsolete, Seiko USA has both in stock.
The issue is that Seiko USA does not sell to individuals or repair shops unless they have an account, that is authorized service centers.
BTW, we have a section here where it's considered polite to introduce themselves.
On 12/3/2019 at 12:17 PM, jdm said:
The issue is that Seiko USA does not sell to individuals or repair shops unless they have an account, that is service centers.
Your information is incorrect. I am not an authorized Seiko service center, I am a authorized Seiko dealer and Seiko USA does indeed sell parts direct to its dealers.
The point however is that a quick login to Seiko's website shows that  the genuine Seiko crystal, 310P03HN02 is not obsolete, and in fact Seiko USA has over 50  in stock.
I just don't get why you keep banging on this drum. Facts:
The issue is that Seiko USA does not sell to individuals or repair shops unless they have an account.
Am I incorrect?
Login to that "Seiko website" is reserved only to dealers, or service shops. Am I incorrect?
Now, if you're implying that you're willing to resell Seiko parts personally I don't have a problem with that, but if you wanted to say that individuals can contact any US Seiko dealer just to get parts, I don't think that is an accurate or reliable statement.
Edited by jdm
Am I incorrect?
Yes, individuals can contact any US Seiko dealer just to get parts, however it is up to the dealer as to if they want to sell the parts, and unless they have a watchmaker in house I doubt they will.
Myself, I sell only to other local watchmakers when they are in a fix and cant get them any where else or need technical help.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
