Cleaning a movement
Yes it is, a 1974 6139-6015 to be more specific. The watch runs pretty well considering it has never been serviced (at least there's no service stamp on the case back, so at least not professionally serviced). The pushers weren't operating the chrono, but after pushing them probably more times then i should've, all of a sudden they're now working! The top pusher starts the chrono no problem, but is a little finicky when stopping it. I click it to stop it, and if that doesn't immediately stop it i just gently squeeze the top pusher without depressing it fully and that stops the chrono. The flyback works too. I'm guessing that this watch just needs a really good cleaning and not the $395 servicing my local watch repairman suggested!
Yes, I'm sure it would benefit from a proper cleaning and lubrication. Have you stripped a chronograph before? The difficulty is in the correct reassembly with proper oil. Lots to keep track of....
22. 6139A.pdf
Minimum oils are Moebius 9010, and 9501 for keyless works, but you'll find lots of information online specifically for chronographs.
J
Edited by noirrac1j
No, i'm very new to the watch servicing side of things. I will just enjoy the watch in its current functioning state until i work up the nerve to service it by practicing on a bunch of junker watches. If the watch has gone without servicing for 44 years, another month of two shouldn't hurt it!
What cleaning solution(s) are best for cleaning parts in an ultrasonic cleaner? I've ordered a cheap cleaner (no heater), is the solution used water mixed with something, or is it an actual cleaning product?
Use quadralene. It’s reasonably priced too. They also manufacture a rinse matched to the cleaner. I use it in a small jam jar stood in the u/s tank, filled with warm water. Works well
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
