Anybody fancy plank for dinner?
It can be fixed using the original holding arms. As a prototype it’s very much a work in progress. If my mate approves the concept then we will work on the fixes. The work will be improved (not my Heath Robinson approach:) ) and my choice would be to have a number of colour options available using different veneers and leathers
I thought this was a one off, if you are doing it as a selling item maybe try a few of these things.
To get the curve, use 3mm ply cut 3 pieces to size, make a jig, a bit like a bricky uses to get a curve on an arch opening, however have a male and female, glue with PVA the 3 pieces together and clamp it, when dry they will hold the shape.
To tidy up the top, take the front  level with the curve and hinge with a piano hinge and use a magnetic clip at the bottom , that way you have a door to access the movement. This will let you add a bottom to the case, a few strechers across the top and it will be strong.
I am not saying the way you did it is wrong, just trying to help in the ongoing project.
Thanks Jimmy, I do appreciate the advice. The way I’ve done it wouldn’t be the best way and needs improvement. I’ve done this one purely as a prototype to show the design to see if my mate would like it. He has a stock of twenty or so movements and wants a unique design to put them in. This was my idea for him and also a little project to house the little French movement. If he goes for it then we would work on the design to get it right fixing the problems and sorting out the best manufacture process. I’m pleased with the look and blend of materials and personally think it is quite smart, modern looking with a nod to the old.
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
