Anybody fancy plank for dinner?
Coming along nicely, I had to do something with the little French movement and there were no cases suitable coming along so I decided to have a go at making one. There is a reason for all these shenanigans but more about that if anything comes to fruition.
4 hours ago, Squiffything said:
I know there are proper ways of doing things but I just don’t have the tools and equipment to do it the correct way so time to experiment.
If it works then why not!  :Bravo:
Whilst a lot gets said about the 'correct way' to do things, experimentation is how the 'correct way' became so regarded.
Looking forward to seeing the outcome, I am rather curious now...
Thought about that and also a door to access the movement. There will be no base (got to let the chime sound out) so access may be had from there.
Looking forward to polishing up the burr, I love working with wood and getting a good finish.
Edited by Squiffything
Looking forward to see the end result.
Used to live next to a carpenter who restored old furniture picked up at local auctions as a hobby.
He used to use an old wallpaper steamer as a source of steam when bending wood.
Sent from my moto g(6) play using Tapatalk
It’s attached. Wood glue finely spread and left until tacky then the leather stretched taught. Trimmed to fit.
I’m unsure how the case will be assembled, either screws that will be on display or covered with some kind if fake rivet head if I can find any. The ulternative would be to screw from the inside but that would need a curved frame and there’s not much to then go into in the leather covered ply. Glue and tacks might be the way but would not be as strong and the curve might give problems as it tries to pull away.
I’m thinking that evenly spaced brass screws might look good set into the black of the leather.
The front panel housing the clock will also be covered in leather so only the sides will have the burr wood finish.
The first few coats of Danish oil has been applied and the burr has really popped. It’s a fantastic process and takes time. Different to French polishing in that when it’s finished it will glow with a shine but will not have that glass like surface that a French polish has. I will apply a varnish at the end to give it a protection.
The front plate has received its leather coat and looks mighty fine, also popped down to the local hardware shop to see what they had by way of fixings. Not much :( the did have mirror screws with the rivet type heads that screw onto the end of the screws. They are a compromise and I will look to see if I can find any black or brass caps but they do not look too bad.
Right, back to the wood, these coats will not layer themselves.
8 hours ago, JimmyD said:
I am not sure so I will ask the question, does oil not prevent the varnish from adhearing?
My understanding is that the oil soaks in to the fibers of the wood, swelling them slightly and turning them from fairly opaque to translucent, and since the oil is mainly in, rather than on the fibers, and is also compatible with the finishing coat  it doesn't really affect the varnish.
The finish (synthetic varnish, shellac or whatever)  adheres to the wood fiber surfaces and to itself, effectively producing a bonded membrane.
There a few tweaks that will turn an Ok result in to a spectacular one.
First ensure the surface is as finely sanded and blemish free as possible, to the extent that french polishers will fill the tiny blemishes with pumice powder, and use 000 wire wool to knock down any fibers that insist on spoiling the look. There are  of course a bunch of other tricks, but you need to read up on the subject to learn them all.
Don't to use too much of the oil, and apply it as several light coats, as it may not fully soak in if you are not careful, and  apply the finish as several very thin coats, rather than one heavy one. The more care and time you take, and the more you polish between coats, the better the finish.
Wood polishing, and by extension, French polishing is an art in itself. Quite time consuming, but worth the effort. In my opinion French polishing with a wax finish produces much finer results than simply slapping on a coat of PU varnish. You need a lot of patience though.
Incidentally, that boiled plank dinner is starting to look quite delicious. :P Keep up the good work.
Edited by AndyHull
Thanks Andy. I am not going for a high gloss French polish finish on this one as it’s a prototype to show a guy an idea for a project. If he goes for it then we will work on the finish and tweak the design.
I never was much good at drawing so making it seemed the best way to go. It’s all from scrapage and spares from down the shed and it’s kept me busy for a couple of days.
You can remove the movement from the front. It’s a snugg tight fit around the bezel no need for screws. If anything comes from it the design will be improved with a door at the back hinged in the curve like a car boot and a opening in the front to view the pendulum. Maybe a draw under that to house the key
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
