    • Hello everyone, My name is John but you can call me Jack. I am new the group here and have been a hobbyist repairer for the past 2 + years. I mainly stick with mechanical watches but from time to time I will tinker with old quartz Seiko watches which I love. A current project that I have been trying to get down is a Seiko 4336 8129. This watch has been fighting me from the start. Well the movement was dead due to a broken pivot on the motor. So I sourced a replacement movement. Next Crystal was cracked so I removed the broken glass but can't figure out how to take the top bezel ring off. I have some pics. This poor watch has had a rough life. I was trying to bring it back!! Thank you for reading my tale of woe!!
    • I am looking for a camera with a macro function to photograph my work.  I had a 18 or 20 megapixel Sony point and shoot that worked great for super close pics, but lost it in a fire.  Dont remember the model but it was a pocket sized camera I could zoom and focus on pallet stones with excellent definition.   It was less than $200 US.   Now I can’t find a camera that will do the job for less than $500  Any suggestions?
    • Can you repair my Timex Rally also?
    • I have a small confession. I "fixed" it after that picture was taken, by carefully carving the notches back in to the brass with a sharp knife. It looks and winds a whole lot better, but yes, the real fix would be to replace the crown. The wear  to the crown and the plating suggests this is a well used watch, so the results of the service are all the more impressive. Edit: The crown carving was done by removing the crown and stem assembly and grabbing its shaft in my rechargeable drill's chuck, then cutting in to the surface with a sharp modeling knife blade. The original notches were barely visible, so some good light and a steady hand were needed. The result is vastly improved in terms of both looks and function, but a new crown would be the correct solution to the problem.
    • yikes that crown is worn!
