Regency 17 Jewels watch repair
Hi Folks,
I am writing to you on behalf of a friend who doesn't use computers etc, but is quite a watch and clock collector/enthusiast. He has a Regency 17 Jewels watch, that he says something is wrong with the winding spring in it. He is looking for another watch that he can use to replace the faulty bit. He says the jeweler was unable to repair the watch without this part, which he didn't have. Pictures below. Any advice or suggestions? Kind Regards.
Thank you folks for replying  :) . My friend is going to get back in touch with the jeweler to find out exactly what the name is of the part(s) that needs replacing, is. I guess we (he) should have lead with that. Before clapping eyes on his watch's internal workings, i've barley ever worked on anything like a watch (looks pretty fascinating - tho i somehow doubt he'll let me do a maiden voyage on this watch :lol:). I apologise if i have wasted anybody's time, it was not intentional, rather a learning curve. If we do get the name of the part(s) needed, would it be ok to mention them here, and see if/where we could get it/them?
No problem, No bother. do a search on the bay. vintage mens 17 jewel watch  , thousands will pop up.look through them ,you will find what you need.Alternately you could try speedtimerkollektion.I would tell you to get a whole movement that is sold as needing service. I t will be cheaper and easier than buying one piece at a time.
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
