Budget friendly Bergeon-ique winder/tester
m1ks
A recent purchase which I thought warranted a review.
Chinese Bergeon style winder/tester for auto watches at under £35!
I'm pleased with it currently and will see how it holds up with more use, past 2 days with a morning and evening 2 hour session on an auto plug timer so far.
Always good advice regarding any electrical equipment, (washing machines and dishwashers according to our fire trainer for the nhs are the most common items to cause faults which initially surprised me and I never operate my washing machine whilst out as a result now), the cheap adapter has gone already. It's set to operate only when I'm in during the evening. One thing I didn't cover in the review is that all the electricals are easily accessible to check via a pop on back cover and in this case seem well assembled.
It was a no brainer for me, I was looking at a twin winder with storage cushions for 6 watches on eBay, the largest nice display type I could find but that was £50 ish and would need swapping watches around daily or so.
Admittedly this isn't a pretty display box but it should do what I need.
Can't say my Bergeon winder is as quiet as this. But it's pretty old and have turned many times. Could stand the noise from it during the day but don't think i could sleep in the same room.
Edited by rogart63
Same as on my Chinese bench motor. Electricals are all insulated and safely installed. One should really look and check what is what , avoid cliche' statements. At some point I want to get one of these testers too.
  • 5 months later...
Hi, is this still holding up well? I'm considering purchasing one. Thanks
Hi, yes, this is still chugging along, twice a day morning and evening for 2 hours each time keeping my Seiko 5 and Orient watches wound.
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
    • The one thing I took time over was to round and polish the curves at the bottom of the jumper arm. The slightest mark (left over from cutting of filing) acts as a stress raiser, just where you don't need it.
    • I printed the base and it is a bit too large to fit on the base of the hand setter. The ring bumps into the column so it is unable to full seat on the central ring. I'm going to try removing some of the materal and see if I can't get it to go down.
