Budget friendly Bergeon-ique winder/tester
m1ks
A recent purchase which I thought warranted a review.
Chinese Bergeon style winder/tester for auto watches at under £35!
I'm pleased with it currently and will see how it holds up with more use, past 2 days with a morning and evening 2 hour session on an auto plug timer so far.
Always good advice regarding any electrical equipment, (washing machines and dishwashers according to our fire trainer for the nhs are the most common items to cause faults which initially surprised me and I never operate my washing machine whilst out as a result now), the cheap adapter has gone already. It's set to operate only when I'm in during the evening. One thing I didn't cover in the review is that all the electricals are easily accessible to check via a pop on back cover and in this case seem well assembled.
It was a no brainer for me, I was looking at a twin winder with storage cushions for 6 watches on eBay, the largest nice display type I could find but that was £50 ish and would need swapping watches around daily or so.
Admittedly this isn't a pretty display box but it should do what I need.
Can't say my Bergeon winder is as quiet as this. But it's pretty old and have turned many times. Could stand the noise from it during the day but don't think i could sleep in the same room.
Edited by rogart63
Same as on my Chinese bench motor. Electricals are all insulated and safely installed. One should really look and check what is what , avoid cliche' statements. At some point I want to get one of these testers too.
  • 5 months later...
Hi, is this still holding up well? I'm considering purchasing one. Thanks
Hi, yes, this is still chugging along, twice a day morning and evening for 2 hours each time keeping my Seiko 5 and Orient watches wound.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
