Help Putting collet on hairspring
If a new spring, set the collet on top and see how much (if any) inner spring you need to remove. Ideal would be the collet just fits in the coils plus a little play. Now form the bit that will go in the collet.
Slide the collet on a smoothing broach. Get the bit of spring in the hole, then in goes the taper pin. Be sure the pin is on the same side of the spring! Level the exiting part, seat the pin. Now trim it with very fine nippers. With a small fine file (6 or 8 cut), with the side honed smooth, trim the pin and fully seat the pin, then retrimming the exit side. It will look horrible until you trim the pin, but if you eyeball level the 90something degreed from the pinned point it'll look pretty good after trimming.
Now you need to level and true in the round properly. It's fine work.
It's handy to have a tweezer with one end shortened for fully seating the pin.
4 hours ago, jdrichard said:
I need to know the best method of putting a collet on a hairsprings...tools and techniques. Before I jump out the window.
To bad you can't read Swedísh? Or can you? Have a very good book in the subject. It's call spiral and balances.  Tell you  everything you need to know. I can take some pictures and see if i can translate . Don't think the book is translated either.  DSC00131.thumb.JPG.4b36ab61d371b019a9f96adb5c0b5f60.JPGDSC00130.thumb.JPG.6be278ed90f78f2449db1132b7ee072a.JPGDSC00129.thumb.JPG.8e2fa5c404d699b4572d61fec8f3a42c.JPGDSC00128.thumb.JPG.be444efcea92f740cc440c74ec6ac5d4.JPG
This is very very nice of you. I'll look for The book.
How do I prevent it from spinning around when it is on the broach? This was an issue. As well the collet will not fit in the smaller diameter of the hairspring with the Bend already established. Perhaps need to cut away a bit of spring.
You stck it on the broach tight enough that it doesn't spin. Getting the inner end of the hairspring in the hole is kind of like potty training a 2 year old- you just have to coax ot in. The pin is similar. I used to do this on video camera for students 20 years ago and now I got nothing unfortunately.
4 hours ago, nickelsilver said:
Getting the inner end of the hairspring in the hole is kind of like potty training a 2 year old- you just have to coax it in.
.. and no doubt just as frustrating (but perhaps less messy) when it doesn't work. :D
Is that book written by Sven Sandström? You wouldn't have a second copy?
Definetly frustrating as heck. I am going to try again today...and stay away from the window.
This one is made from a thick brass rod and tapped for a retaining screw and tapered to ensure the screw does not spread the collet when tightened.
This one is made from a tapered rod with a second dial used to seat the hairspring and collet. I like the first tool and shall make one.
Exactly . I am afraid not . I have pictures that i sent to a friend of every page. But i guess it's hard to read . But send me a PM . Maybe can send it to you on mail.
Bought it from bokbörsen.se. Maybe someone else has it there?
Edited by rogart63
Case closed:)
Jd the best tool for holding an HS collet is this you can clamp it where you like and you have a good platform for the HS to rest on if you need to manipulate the HS hope this helps Kaz
Having done this work more than once,  I suppose this tool is no advantage to the traditional method mentioned by Nickelsilver. By the way, I found fixing the collet to the hairspring is easier than expected.
But making the tool gave you a nice delay before having to start the real task :)
Frank
Edited by praezis
I have to agree. The hairspring will need to tilt quite a bit when inserting the pin (it looks frightening), like 45 degrees. Anything that impedes that will make pinning 10x harder to impossible. I didn't see an image in a book, will try to get a pic of it.
But making the tool gave you a nice delay before having to start the real task [emoji4]
Frank
The tool should work. And I can tap various size holes for different collet hole diameters.
OK tried to get a couple of pics, the tiltedness of the hairspring doesn't look so bad but getting the pin in it does need some space to move around up and down. What's important when seating the pin is that the first bit of coil be as level as possible (you can see it a bit in the first pic). Also, as close as you can to true in the round. Once the pin is seated nip off the extra with tweezers like shown. Then seat the rest, nip off the little bit that has come out, and if doing a nice job clean up the exit point with a really fine file.
I tried this method a few times and was totally frustrated
Sent from my GT-N5110 using Tapatalk
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
