Seiko 6119c hair Spring
not sure but seems like you have to measure the diameter and collet bore, then select material. My concern would be the stud, guessing you have to attach the old stud to the new spring. seems like too much of a hassle. there are plenty of working movements on ebay for $30 or less. I have two of them if you need one
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
