Unknown pocket watch
I have today picked up a pocket watch to play with and try and get working. I have no knowledge at all what it is so am asking the collective for any information and help.
The movement is loose and has two steel bands inside one of which has rusted. The hands are not there but will be arriving at the weekend. There is no glass so will need to be sourced. I’m not sure if the case is gold, plated or whatever but it will need a polish, any suggestions.
Thank you Nickelsilver. Ok it’s a fusee movement in reasonable condition and one I don’t think I should mess about with. On the movement is 3839 and in a different place Patent so not sure if that is the patent number or movement type.
It has a gold stamp (crown) with 18 underneath and there is on EBay at the moment a very similar watch with the same case (slightly different) which is listed as three colour gold which this appears to be.
There is a stamp mark which appears to be JLS & Co but I cannot find them listed. Ok I got a little fed up with hundreds of sites for some kids boy band and gave up :(
Looks like an English fuse pocket watch. They are entirely different to what I would call an average pocket watch movement. If you have never repaired, a fusee you need to read up and understand how the fusee works. You must be extremely careful with the chain. If the case is gold it will be hallmarked and you will be able to date it. I would say its around 1840.
It’s hard to show on a phone camera but the face, after a quick clean has come up lovely. You can see three colours of the gold which I think is white, rose and yellow.
Now just have to order a new glass and await the hands. Any advice on what glass I should look for?
I would wait until you have it assembled then measure the height of the centre wheel and see what clearance you will have between the tip of the minute hand to the bezel. It should be glass and not that plastic stuff. Depending on the inside, lip of the bezel should give you a good idea on the thickness.
If the S is the hallmark it looks like Oldhippy was pretty on the money as its 1833.
http://www.thebigworld.co.uk/dating_english_hallmarks_silver_and_gold.htm
As oldhippy says you need to do some research before touching this watch it is completely different to modern watches.
The best book I've seen on how to strip down and service these watches is by Archie B Perkins 'Antique Watch Restoration Volume 1', but its expensive at £75.
A much cheap but not as good book is 'The Pocket watch' Restoration, Maintenance and Repair by Christopher Barrow, although his book does cop some criticism, but does have good colour photos in it.
There looks to be something wrong with the hinge plate that the dial is pinned to. It should have pillars coming down to pin it to the movement, but I can't see any and it looks like the pillars may still be in the movement, so they may of been pulled out of the hinge plate and will need to be rivetted back in or replaced.
If you can give a good photo of the hinge plate I'm sure OH will be able to say for sure.
What a great find, I'm very jealous.
Another issue is that the back plate of the case is stuck firm I can see that there is a hinge for it and I thing that it should be opened by a button on the top. This should press down onto the rusted steel plate inside the rim of the case. Does anyone know if these can be bought as spare parts? How are they removed?
The case springs do turn up on ebay from time to time, there are several lots on ebay now, but not sure if they are correct for your watch.
Do an ebay search for 'pocket watch case spring'
As a side note normally you would remove the pin on the hinge to remove the whole movement from the case and after removing the hands then remove the dial and hinge plate from the movement.
If you don't have the taper pins to reattach use brass, not steel taper pins to attach the hinge plate to the movement
My Brother in law clears garages and lockup’s and found it years ago. Never did anything with it but thought it was too nice to throw away. Bought it up at the weekend and is coming up on Sat again and will bring the hands which he has. As you said lucky it wasn’t scrapped.
    • In the meantime whilst awaiting a better plan, please drop me a quick hello on my email.
    • I looked at it like this, I've built a lot of stuff in my time, building structures and furniture,those are my creations and they will still be here way way after I'm gone. Traditional watchmakers felt the need to pass their knowledge on, ideas that they created . I assume with them as it is with me, leaving their mark on the earth, a way of being remembered. This creation of Mark's has brought thousands of people together to pass their knowledge around,  ideas that will continue to be used for lifetimes. Ideas that should continue to be procured. If for whatever reason the forum ceased to exist, not quite like Ranfft's, that didn't disappear but much less usable. Then that is sad, such a massive loss of communication between good people and a wealth of knowledge lost. There should be something in place for when that happens which could be next week, next year or in 10 years. Might not be a topical subject for a lot of folk or boardering on controversy, i did say i talk about stuff other people dont. But if you dont talk about it and something happens then you've lost it and you ain't gonna fix it .
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
