ETA2408 Balance Complete
Hello. I am looking to buy an ETA2408 balance complete for a project I’m working on. If anyone has one surplus to requirements that they’d like to swap for beer tokens please pm me. Alternatively, if you know of a supplier in the uk, if be most grateful to hear from you. Kind regards Deggsie.
Well I don't know which reqirements you mean since the 2408 like all other stuff from them comes in different shapes and materials, I got one for a 2804 slightly higher grade, it looks good but might not work for your movement, but in worst case if you don't find one I can send it to you to play around with. Just pop a private message.
Just to update you all. Thanks to HSL kindly sorting out a balance complete for an eta2408, I’ve now brought this attractive gents accurist back to life. Thanks HSL, much appreciated sir!
74b431e76e24459afeb2d9638cfc2e3a.jpg&key=59e2cce36ebe8d3812b1f05b5f691e76c30f28f12e786387e6c598202744a8a0
