[3D-Printed] Watchmaker Tools - Bergeon Style Prat Dust Tray
Interesting! I just got a JLC Memovox 3151, calibre P489/1. The amplitude drops by 70° from horizontal to vertical. Good to know that this isn't too unusual. Btw, if anyone is ever searching: the lift angle on my P489/1 is 60° - as calibrated through visual (slow motion) inspection of the balance swing. This differs from the 40° lift angle found on various lists on the Internet. Makes a huge difference, obviously, in the timegrapher amplitude readings. Cheers
Have you looked here. https://moleroda.com/radial-wheels-for-cleaning-and-polishing/
The problem sounds very much like what might happen when failing to do the reset procedure. The stopwatch not working could be a few things. There are two different motors, one for the center sweep seconds and one of the minute counter. Damaging a coil is the most likely thing to do wrong when changing the battery, but that would likely just take out one of the two. So "start" it wait and see if the minute counter doesn't tick over. If that ticks, and you've done the reset procedure, it's probably damage to the sweep second coil. If neither works, then it could be the button contact is damaged. It's a tiny bit of copper trace on the PCB that curls around the edge to make a circuit and it can break off. There's a way to trigger the buttons from the small pads on the back of the movement, as well as check them with a multimeter, if you are familiar with one. But give this a try, pull the crown out to the second position and hold down button "B" (10 o'clock) for a few seconds. This is suppose to spin the minute counter to let you reset it to 0. If it doesn't move and (I assume) button 'A' (2 o'clock) doesn't start the chronograph, then either both buttons have failed at the same time or there is something else wrong. A leaking battery can take out the traces on the circuit board, and this can take out the motors and/or buttons, but you didn't say anything about it and it should be obvious if it leaked enough to do that.
