My latest project
Gram
Hi Guys,
My latest project is this Poljot P3133, photos attached.  It's had a clean (by hand so not completely shiney!) and it's up and running.  The hinge on the case is broken and I'm having a tricky time finding someone in Cambridge to repair it.  Most say they won't touch it because any heat applied will of course cause the gold plating to peel off.    If anyone has any good ideas about the case I'd be much obliged, thanks.  I broke one of the Liar springs and replaced it with a Valjoux Incabloc spring which seems to work OK.
Here are a couple of pics.
Kind regards,
Graham
