Indian Allwyn watches
Has anyone here worked on an Allwyn manual wind 17 jewel movement?
I bought one yesterday, (awaiting delivery), because the movement image intrigued me, the crown pinion doesn't have a screw head as you'd normally see but looks more like a rivet or Allen bolt with the hole but without the hex sides to it.
It's simple curiosity and being Indian and a bit different I wanted one for my collection and to see why that design when I try to strip it.
Apparently they were a collaboration between Seiko, possibly they didn't like hmt/citizen getting all the glory in India?
I suspect they may have a nearly identical clone Citizen 1802 movement to the manual HMT 0231 based watches, or perhaps one of the manual Seikos. I picked up a franken "Sieko" automatic which has an Allwyn automatic movement which is stamped A6319 - and is a clone or re-badged Seiko 6319A
Either way, I would expect it to be a robust, well constructed workhorse movement. Don't forget to post some pics when it arrives.
Edited by AndyHull
1 hour ago, AndyHull said:
Does it look anything like this perhaps?
If so it is probably a derivative of the Seiko 6310A
It does indeed Andy. Thank you.
I never thought of doing a search for Seiko movements to see. Bit silly considering I'd read that they were a collaborative effort and I knew HMT were a clone Citizen.
I'll share pics when it arrives.
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
    • I bought this box of jewels a few years ago and noticed that the glass containers are divided into two sections. In the first section, the containers have a label with red text colour and always start with the letter B. In the second section, the text on the label is black and lacks the letter B. There seem to be roughly the same number of containers in both sections, and each section has the same sizes of jewels. The only difference is that the jewels in the B section with red text have a slightly rounded, convex underside. My question is what are these rounded jewels for and if I can use them instead of the jewels with a flat bottom if a certain size is missing?
