Intriguing ETA 2678 issue
What I'm confused about is the fact that with all the parts in place it only slips when adjusting the hands clockwise. If I adjust them counter-clockwise it works fine.
I'll try loosening the canon pinion... Out of curiosity what is the correct way to loosen such a canon pinion ?
Are you supposed to slightly pull the 2 tabs that hold the tube outwards or what ?
Also I still get the impression that the small steel gear might not engage properly with the minute wheel due to pivoting just slightly. Not sure.
Edited by Chopin
How come the screw is wrong ? How does the screw influence all this ?
What should I be looking at exactly ? How does one know that it's wrong ?
PS: that little plate (that covers the parts) is flat from what I can tell.
Edited by Chopin
lol ..no need to rip your hair off
Unfortunately I didn't have the ETA 2678 at home right now but as happens I got a few ETA 2671 whitch is the same movement except without the day indicator.
I guess the screw is the one I have circled in yellow , on these small movements they actually looks like this when they come brand new.
What you should check is if the day/date dials is moving smooth, if they dont then it might cause the stress to break a tooth on the wheel.
While your at it check the yoke action is nice and crisp, if it's weak the sliding pinion might just tuch the tips and that will break the teeth too.
Since you say it works when you take the cannon pinion out it might just be in the progress to change date/day and just got stuck.
Photo of the screw and plate.
It seems like this circled part below is moving just a bit downwards (talking about the tip that holds the gear not the entire part) but only when the hands are adjusted clockwise and only when it reaches the borken tip does the gear that it holds start to slip and not engage with the minute wheel.
Also, strangely, if I take a few parts out and put them back it can run well for a few rotations but then something goes bad and the issue begins to repeat. It's as if the canon pinion is smoother and then it becomes a bit stiffer...
Edited by Chopin
You shouldn,t pull the two tabs , oil the canon pinion groove that sits between the two tabs, instead.
Clean and lube the date jumper. The min train and date train + date jumper+ day change, should altogether turn nice. Excess resistance and unlevel min train cover/ bridge will cause one gear to ride over the pinion of the other, that has been the case here. I think Mark put some oil on top of min gear in between min gear and its cover.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it.
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
