Zinc or Tin Plate for Black Polishing?
Tmuir
I'm looking at having a go of the dark art of black polishing, in particular I want to learn it for restoring old pocket watches for parts that have suffered minor surface damage.
I'm going to cast and then machine my own polishing plate.
All the books talk about using Zinc for steel parts and I have read tin for gold parts, but online have read about a few people using a tin plate for steel parts.
Tin will be easier to cast than zinc, but I should still be able to manage to cast zinc, but just want to know if anyone here has tried black polishing and if so have they used a tin plate, or should I go the extra effort and cast a zinc plate?
I have both and prefer tin. Some folks add a little silver to the tin (I've heard between 1-5%) for a little more hardness; I have a couple and also pure tin and can't tell a huge difference.
Just avoid lead or tin/lead alloy. The lead is toxic and its oxide is just abrasive enough to make polishing next to impossible.
What's more important than composition is that the block be flat and not too smooth (rough lathe finish or scratch it up with a file), and not too much polishing paste. It needs to get almost dry to hit the black polish.
Thanks, I plan on buying pure tin from a foundry in Queensland that sells it in small amounts to hobbyists for reasonable prices so don't need to worry about the purity.
With Zinc I would of had to gone done the path of green sand casting, but with tin I should be able to just get away making the mould with just getting some hardwood and using a hole saw drill a hole through the wood and clamp it onto  another bit of wood.
Yes the wood will likely smoulder a bit, but that doesn't matter for a one off use mould.
What diameter are your plates?
Thanks, I was thinking around 100mm, but its always good to get confirmation.
A silicon mould would concern me to use as its max temp is only 30C above the max use temp of tin, but I guess if you are careful it could be ok.
I ordered last Friday 3 kilograms of high purity (>99%) tin from a foundary, its currently in the post and should arrive late this week. (Cost a fortune)
Its my son's birthday this weekend so I doubt I will get a chance to cast the plates this weekend, but when I do I'll be sure to take photos of my whole process.
3kg [emoji23] you'll have everything in a 1/2 mile radius polished. Joking of course, that's really cool. Do you have a tripod/bolt tool?
17 hours ago, nickelsilver said:
3kg emoji23.png you'll have everything in a 1/2 mile radius polished. Joking of course, that's really cool. Do you have a tripod/bolt tool?
I bought enough to make at least 3 polishing disks, so I can use different ones for different diamond pastes.
I have in the post a tripod tool for polishing flat parts, but not screw heads, if I cant find one soon for a reasonable price It will likely become a project for me to make one.
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
    • Ok thanks Ross, I will give that a try!😁
