Balance jewel removal question
I have an old watch stripped and have come across a different type of balance jewel that I have not done before. The movement is a Culmina. I have removed the plate and end stone from the lower pivot but the jewel itself is reluctant to come out. The one on the balance cock is secured from the underside. I am very apprehensive about disturbing the hairspring, removing the spring and wheel seems the only way to safely gain access. It might end in disaster. I’m thinking about just cleaning them in situ, not sure how I will lube them again though. I might practice on an old balance then come back to it. I need a better loupe, not to mention steadier hands!  Here are some pictures.
6C2B9CF8-70AF-4166-940C-566B5D4A2AA6.thumb.jpeg.1361588e5d1e0049b90a2fc2a1c14020.jpegF247830D-3034-4854-BB8E-F41D7F92B22D.thumb.jpeg.c0f8d5fc765b721c580ee69f54396fa3.jpeg3F39B0BC-7A1F-4840-A607-6ADD776AEC1D.thumb.jpeg.78430a12315bd32684794510e8a26cb5.jpeg
[mention=4872]Nucejoe[/mention]  Yes it’s in the slot, just not easy to see in the picture.
[mention=4990]nickelsilver[/mention]  Safer to leave them in rather than risk any damage I suppose.  How might I get some lube onto them?
Thanks.
Lube them like old school cap and hole jewels, assembled, bit of oil in the cup of the hole jewel and feed it through with a thin wire. There are oiling tips made for this, gold handle with replaceable little wire tip, extra tips in the handle. I usually use fine hairspring taper pins though.
End stone and jewel chaton may be sticking togther by some varnished oil. If you feel they are.
I screw the cock back on the mainplate, without the cab springs, place mainplate+cock in jar with a few CC fluid. close the lid ,gently shake to move the fluid round for a min or two, you will see the cab has come off, no longer on the jewel.
The purpose of shock springs is to absorb shocks from end stones, that means end stones are removable. This can,t be rub in jewels since it has got shock springs.
Regards
Just remove the balance wheel with hairspring and take the cock the cleaning machine... You can soak and shake complete balance in contact cleaner too... Use air blower to rinse it... The result is perfect...
Edited by Asmobrat
Looks like the complete regulator arm comes off??
Yes this- missed that op was timid about taking the cock apart. The whole regulator comes off, hairspring first of course. Clean, reassemble, then oil assembled.
The two screws just hold the shock spring, don,t seem to have anything to do with the housing.
I stole this from a jdm post, shows pin and boot of regulator pin. Slot is where your screwdriver goes in, turn to let HS out.
Place the cock on hard flat surface like you show in your pic.
Moving the balance with HS away from the pins by 3 mm wont hurt the HS, but opens the coils apart so your hand has more space to shake without touching the HS.
I had stolen myself first, If I could remember where I would give credit as it's a great picture.
My idle question,  looks like the balance has regulation screws, so what's the point of having a regulator also?
Could this balance be a replacement, original balance could have been anulare. Hey I am suppose to ask the questions( the easy part):stuff:. You are to give answers.
Right, so I've found:
Which has a smooth rim. But could be that the diabolical Swiss could be that they made some variants with screws to make it look it better, or just different?
So far as I understand the screws on BW provide a micrometer action to facilitate percision poising and regulation, though not primarely for accuracy in regulation.
Accuracy can effortlessly be regulated by regulator arms. Designer must have sold well the screws- micrometer action of the regulator arm, which by itself is an instrument of percision.
Mobile stud holder, stud carier, could then house the micrometer- screw, as well as facilitating for the impulse jewel to be brought in beat without having to disturb the roller or HS collet.
Put all together for ease of some otherwise painstaking operations.
Regards
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
