Balance jewel removal question
I have an old watch stripped and have come across a different type of balance jewel that I have not done before. The movement is a Culmina. I have removed the plate and end stone from the lower pivot but the jewel itself is reluctant to come out. The one on the balance cock is secured from the underside. I am very apprehensive about disturbing the hairspring, removing the spring and wheel seems the only way to safely gain access. It might end in disaster. I’m thinking about just cleaning them in situ, not sure how I will lube them again though. I might practice on an old balance then come back to it. I need a better loupe, not to mention steadier hands!  Here are some pictures.
6C2B9CF8-70AF-4166-940C-566B5D4A2AA6.thumb.jpeg.1361588e5d1e0049b90a2fc2a1c14020.jpegF247830D-3034-4854-BB8E-F41D7F92B22D.thumb.jpeg.c0f8d5fc765b721c580ee69f54396fa3.jpeg3F39B0BC-7A1F-4840-A607-6ADD776AEC1D.thumb.jpeg.78430a12315bd32684794510e8a26cb5.jpeg
[mention=4872]Nucejoe[/mention]  Yes it’s in the slot, just not easy to see in the picture.
[mention=4990]nickelsilver[/mention]  Safer to leave them in rather than risk any damage I suppose.  How might I get some lube onto them?
Thanks.
Lube them like old school cap and hole jewels, assembled, bit of oil in the cup of the hole jewel and feed it through with a thin wire. There are oiling tips made for this, gold handle with replaceable little wire tip, extra tips in the handle. I usually use fine hairspring taper pins though.
End stone and jewel chaton may be sticking togther by some varnished oil. If you feel they are.
I screw the cock back on the mainplate, without the cab springs, place mainplate+cock in jar with a few CC fluid. close the lid ,gently shake to move the fluid round for a min or two, you will see the cab has come off, no longer on the jewel.
The purpose of shock springs is to absorb shocks from end stones, that means end stones are removable. This can,t be rub in jewels since it has got shock springs.
Regards
Just remove the balance wheel with hairspring and take the cock the cleaning machine... You can soak and shake complete balance in contact cleaner too... Use air blower to rinse it... The result is perfect...
Edited by Asmobrat
Looks like the complete regulator arm comes off??
Yes this- missed that op was timid about taking the cock apart. The whole regulator comes off, hairspring first of course. Clean, reassemble, then oil assembled.
The two screws just hold the shock spring, don,t seem to have anything to do with the housing.
I stole this from a jdm post, shows pin and boot of regulator pin. Slot is where your screwdriver goes in, turn to let HS out.
Place the cock on hard flat surface like you show in your pic.
Moving the balance with HS away from the pins by 3 mm wont hurt the HS, but opens the coils apart so your hand has more space to shake without touching the HS.
I had stolen myself first, If I could remember where I would give credit as it's a great picture.
My idle question,  looks like the balance has regulation screws, so what's the point of having a regulator also?
Could this balance be a replacement, original balance could have been anulare. Hey I am suppose to ask the questions( the easy part):stuff:. You are to give answers.
Right, so I've found:
Which has a smooth rim. But could be that the diabolical Swiss could be that they made some variants with screws to make it look it better, or just different?
So far as I understand the screws on BW provide a micrometer action to facilitate percision poising and regulation, though not primarely for accuracy in regulation.
Accuracy can effortlessly be regulated by regulator arms. Designer must have sold well the screws- micrometer action of the regulator arm, which by itself is an instrument of percision.
Mobile stud holder, stud carier, could then house the micrometer- screw, as well as facilitating for the impulse jewel to be brought in beat without having to disturb the roller or HS collet.
Put all together for ease of some otherwise painstaking operations.
Regards
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
