Balance jewel removal question
I have an old watch stripped and have come across a different type of balance jewel that I have not done before. The movement is a Culmina. I have removed the plate and end stone from the lower pivot but the jewel itself is reluctant to come out. The one on the balance cock is secured from the underside. I am very apprehensive about disturbing the hairspring, removing the spring and wheel seems the only way to safely gain access. It might end in disaster. I’m thinking about just cleaning them in situ, not sure how I will lube them again though. I might practice on an old balance then come back to it. I need a better loupe, not to mention steadier hands!  Here are some pictures.
6C2B9CF8-70AF-4166-940C-566B5D4A2AA6.thumb.jpeg.1361588e5d1e0049b90a2fc2a1c14020.jpegF247830D-3034-4854-BB8E-F41D7F92B22D.thumb.jpeg.c0f8d5fc765b721c580ee69f54396fa3.jpeg3F39B0BC-7A1F-4840-A607-6ADD776AEC1D.thumb.jpeg.78430a12315bd32684794510e8a26cb5.jpeg
[mention=4872]Nucejoe[/mention]  Yes it’s in the slot, just not easy to see in the picture.
[mention=4990]nickelsilver[/mention]  Safer to leave them in rather than risk any damage I suppose.  How might I get some lube onto them?
Thanks.
Lube them like old school cap and hole jewels, assembled, bit of oil in the cup of the hole jewel and feed it through with a thin wire. There are oiling tips made for this, gold handle with replaceable little wire tip, extra tips in the handle. I usually use fine hairspring taper pins though.
End stone and jewel chaton may be sticking togther by some varnished oil. If you feel they are.
I screw the cock back on the mainplate, without the cab springs, place mainplate+cock in jar with a few CC fluid. close the lid ,gently shake to move the fluid round for a min or two, you will see the cab has come off, no longer on the jewel.
The purpose of shock springs is to absorb shocks from end stones, that means end stones are removable. This can,t be rub in jewels since it has got shock springs.
Regards
Just remove the balance wheel with hairspring and take the cock the cleaning machine... You can soak and shake complete balance in contact cleaner too... Use air blower to rinse it... The result is perfect...
Edited by Asmobrat
Looks like the complete regulator arm comes off??
Yes this- missed that op was timid about taking the cock apart. The whole regulator comes off, hairspring first of course. Clean, reassemble, then oil assembled.
The two screws just hold the shock spring, don,t seem to have anything to do with the housing.
I stole this from a jdm post, shows pin and boot of regulator pin. Slot is where your screwdriver goes in, turn to let HS out.
Place the cock on hard flat surface like you show in your pic.
Moving the balance with HS away from the pins by 3 mm wont hurt the HS, but opens the coils apart so your hand has more space to shake without touching the HS.
I had stolen myself first, If I could remember where I would give credit as it's a great picture.
My idle question,  looks like the balance has regulation screws, so what's the point of having a regulator also?
Could this balance be a replacement, original balance could have been anulare. Hey I am suppose to ask the questions( the easy part):stuff:. You are to give answers.
Right, so I've found:
Which has a smooth rim. But could be that the diabolical Swiss could be that they made some variants with screws to make it look it better, or just different?
So far as I understand the screws on BW provide a micrometer action to facilitate percision poising and regulation, though not primarely for accuracy in regulation.
Accuracy can effortlessly be regulated by regulator arms. Designer must have sold well the screws- micrometer action of the regulator arm, which by itself is an instrument of percision.
Mobile stud holder, stud carier, could then house the micrometer- screw, as well as facilitating for the impulse jewel to be brought in beat without having to disturb the roller or HS collet.
Put all together for ease of some otherwise painstaking operations.
Regards
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
