Balance jewel removal question
I have an old watch stripped and have come across a different type of balance jewel that I have not done before. The movement is a Culmina. I have removed the plate and end stone from the lower pivot but the jewel itself is reluctant to come out. The one on the balance cock is secured from the underside. I am very apprehensive about disturbing the hairspring, removing the spring and wheel seems the only way to safely gain access. It might end in disaster. I’m thinking about just cleaning them in situ, not sure how I will lube them again though. I might practice on an old balance then come back to it. I need a better loupe, not to mention steadier hands!  Here are some pictures.
6C2B9CF8-70AF-4166-940C-566B5D4A2AA6.thumb.jpeg.1361588e5d1e0049b90a2fc2a1c14020.jpegF247830D-3034-4854-BB8E-F41D7F92B22D.thumb.jpeg.c0f8d5fc765b721c580ee69f54396fa3.jpeg3F39B0BC-7A1F-4840-A607-6ADD776AEC1D.thumb.jpeg.78430a12315bd32684794510e8a26cb5.jpeg
[mention=4872]Nucejoe[/mention]  Yes it’s in the slot, just not easy to see in the picture.
[mention=4990]nickelsilver[/mention]  Safer to leave them in rather than risk any damage I suppose.  How might I get some lube onto them?
Thanks.
Lube them like old school cap and hole jewels, assembled, bit of oil in the cup of the hole jewel and feed it through with a thin wire. There are oiling tips made for this, gold handle with replaceable little wire tip, extra tips in the handle. I usually use fine hairspring taper pins though.
End stone and jewel chaton may be sticking togther by some varnished oil. If you feel they are.
I screw the cock back on the mainplate, without the cab springs, place mainplate+cock in jar with a few CC fluid. close the lid ,gently shake to move the fluid round for a min or two, you will see the cab has come off, no longer on the jewel.
The purpose of shock springs is to absorb shocks from end stones, that means end stones are removable. This can,t be rub in jewels since it has got shock springs.
Regards
Just remove the balance wheel with hairspring and take the cock the cleaning machine... You can soak and shake complete balance in contact cleaner too... Use air blower to rinse it... The result is perfect...
Edited by Asmobrat
Looks like the complete regulator arm comes off??
Yes this- missed that op was timid about taking the cock apart. The whole regulator comes off, hairspring first of course. Clean, reassemble, then oil assembled.
The two screws just hold the shock spring, don,t seem to have anything to do with the housing.
I stole this from a jdm post, shows pin and boot of regulator pin. Slot is where your screwdriver goes in, turn to let HS out.
Place the cock on hard flat surface like you show in your pic.
Moving the balance with HS away from the pins by 3 mm wont hurt the HS, but opens the coils apart so your hand has more space to shake without touching the HS.
I had stolen myself first, If I could remember where I would give credit as it's a great picture.
My idle question,  looks like the balance has regulation screws, so what's the point of having a regulator also?
Could this balance be a replacement, original balance could have been anulare. Hey I am suppose to ask the questions( the easy part):stuff:. You are to give answers.
Right, so I've found:
Which has a smooth rim. But could be that the diabolical Swiss could be that they made some variants with screws to make it look it better, or just different?
So far as I understand the screws on BW provide a micrometer action to facilitate percision poising and regulation, though not primarely for accuracy in regulation.
Accuracy can effortlessly be regulated by regulator arms. Designer must have sold well the screws- micrometer action of the regulator arm, which by itself is an instrument of percision.
Mobile stud holder, stud carier, could then house the micrometer- screw, as well as facilitating for the impulse jewel to be brought in beat without having to disturb the roller or HS collet.
Put all together for ease of some otherwise painstaking operations.
Regards
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
