    • As you can tell, vinn3, I have a lathe, but so far it's mostly been for decoration.  I was visualizing the bezel-chuck, and was thinking it could be used by placing the crystal in the center, thereby using the bezel-chuck as a "jawed" chuck. My bad. I do know that the 3-jaw is probably a must for lathe work. I just haven't stepped up to buy one yet. Someday. Until then I guess I'm stuck taking $10 stabs in the near darkness until I get the right size. At least it's not a customer-owned watch. Thanks again. Cheers.
    • Hm, is it possible, that the tube (or a part of it) of the little permanent second hand is still sticking on the pivot of the fourth wheel?How does the hand look?
    • Worldtimer today Needs a case rebuild. Went out for ice-cream and when I got back there was the telltale circle of fog in the middle of the crystal.   https://i.imgur.com/s1wAjoV.jpg
    • I use 3 and 4 jaw chucks, large and small on a "compound lathe".   how does a " bezel - chuck" grab a crystol?  with a 4 jaw,  you invert the jaws and grab the inside so you can cut the outer diameter.   do they make chucks for jewelers lathes?   vin
    • Today, we have a big chunk of 1973 in the form of a Timex Viscount automatic day/date. This repair fought me every step of the way. It arrived with the winder connected to fresh air, and needed a complete strip down to get everything back in order. The day detent spring was misaligned, the date wheel was misaligned, the winder weight was loose, the thing was filthy both inside and out, and even getting the back off initially was problematic. I probably spent a good half hour simply trying to figure out why the day wheel refused to co-operate before I noticed the spring wasn't actually doing anything when the disk was re-fitted, due to the spring being in the wrong orientation. I suspect it got a good hard knock at some stage, which dislodged a bunch of stuff, possibly due to the frustration of the previous owner, as a result of the day wheel not turning. Everything is now all back in order, the hands are correctly aligned, the day and date kick over correctly at midnight. It is ticking away with that characteristic Timex chonk-chonk-chonk and winding nicely. I'm not sure it is going to stay on the hair puller band, I may swap it to something a little more comfortable, as I don't particularly enjoy the bald arm patches look, and my Nordic neanderthal genes mean that my arms are particularly furry. This is what it looked like when it arrived. I'll keep it on for today, and regulate it tomorrow once everything has settled down from the surgery, but it is keeping pretty good time so far. The crystal polished up well, but I still need to give the case back a quick whizz with the polishing pad to get rid of some apprentice marks, probably due to some previous owner's attempts to open the thing.
