Dipping my toe in the cock waters?
SteveT
Hi guys,
I was thinking I'd like to dip  my toe in the waters and see what makes a clock tick.
What would make a good first project / victim? I was thinking a cheap fold up travel clock maybe, if anything just for nostalgic reasons, we had these around the house when I was growing up in the 80's (I don't think they ever got used just sat in a cupboard where I could get my little fingers on them ). Like the one pictured below (I pulled the pic from a google search)
I was there a couple of months ago, be careful it’s addictive!
the advice given, and good advice it was too, is to start simple and initially stay away from the cheap mass produced stuff. They are so built down to price that they are throw away and not ideal candidates for repairs. Good for pulling apart to see how things work but then difficult to get working right again.
my suggestion would be to start on an old mantle type, time only or time and strike. Plenty of Smiths out there for low money and once inside the movements are solid. I was given a Smiths Westminster chime and it’s a lovely old clock. The chime setup is complicated and with three trains to work through it takes time to figure it all out.
Take photos, lots and lots as you dismantle everything. Keep the different trains separated placing each cog run into their own containers to avoid mixing them up and if you can number or mark the order of each train.
There are some top guys on here who will help when things go wrong (and they will go wrong) but when the thing is right and it starts ticking it is the greatest satisfaction of knowing you did that.
good luck and keep us informed
Hi Steve    Wat Sqiffy has said is sound advise keep it simple until your confidence grows. Th time only mantle clocks (one hole in the dial) are chunky enough to play with only the suspension and escapement  are breakable the rest is quite tough, please mind the mainsprings and be sure to remove the tension before undoing the plates as the un tamed power when released can damage the clock and make more work. Take care and be patient as the cock up gremlins are sure to turn up.
If you are going to start on clocks, get yourself a timepiece only. If you want to start with a travel clock, get a Europa alarm. They are easy to work on and if it needs re-bushing you can buy the bushes readymade. You will need a staking tool with punches, just knock the old out and tap the new in.
Thanks guys, I've done a few watches, and I hardly ever break them now [emoji16]. I've been enjoying servicing old Russian watches, cheap and cheerful. But I was curious to see how different clocks are.
I just took a look on the bay at Smith's they look great. There's one listed close to me (so cheap postage) and only $aud20. It's listed as a mantle but the winding key is at the back not on the face?
That is a 30 hour. Here is a photo of the balance wheel and how it is held between the two oil cups. It already shows you how the hairspring should be, also how it is pinned. Three things can go wrong with this. 1 The hairspring can be mangled up, 2 the balance pivots can be worn and need to be put into a lathe and re-pointed with a small Arkansas stone. Picture a blunt pencil then turned into a sharp one. 3 The oil cups can wear inside and need to be re-placed or with the right drills cleaned up.
You cannot re-bush the movements the plates are too thin. I know the photo says alarm clock balance. The clock movement in what you are going for its the same.
At some point, you will need a lathe for clock repairs. Not all of these movements do you find the balance pivots worn. I was just pointing out the major problems that can happen. It might be a good thing to look out for spares; years ago, you could buy a box of replacement staffs. One way to stone the balance would be to hold the staff in a pin vice, rotate it while stoning. I have never undertaken such work in this way.  A few practice runs on steel pins would be a good start.
2 hours ago, SteveT said:
I don't have a lathe is it still worth doing. Hmmmm I'd like a lathe emoji6.png
The lack of a lathe will eventually give rise to problems as the lathe will allow you to do parts repairs/manufacture which will inevitably be required. But you will by that stage be getting to serious levels and the investment would then be worth it.
Also consider the work that will be done is on a small scale so an industrial sized lathe will not be required.
All clock repairing that needs a lathe can be achieved on a Unimat 3. It can handle long case clock barrels and the centre wheels. They do not come any bigger than that. I don’t think for one minute you will be undertaking Turret clocks.
On 4/22/2019 at 10:57 AM, Deggsie said:
Goodness me. I do hope those little electrons at Tapatalk don’t continue to misbehave and randomly insert non horology related photos. emoji12.png
Why Tapatalk? The software that powers the forum has excellent support for mobile browsers. Just try, I think you'll like it.
Hi JDM. You’ll have to ask JohnT as to why he uses Tapatalk. [emoji6]. If you don’t understand, maybe you’re not seeing the full pictures we see on Tapatalk. Oops!
Is it possible for somebody to remove this topic and preserve the young lady’s modesty? I’m as warm blooded as the next male, but I feel this isn’t the place for such photos, accidentally placed or not. Deggsie
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
