Dipping my toe in the cock waters?
SteveT
Hi guys,
I was thinking I'd like to dip  my toe in the waters and see what makes a clock tick.
What would make a good first project / victim? I was thinking a cheap fold up travel clock maybe, if anything just for nostalgic reasons, we had these around the house when I was growing up in the 80's (I don't think they ever got used just sat in a cupboard where I could get my little fingers on them ). Like the one pictured below (I pulled the pic from a google search)
I was there a couple of months ago, be careful it’s addictive!
the advice given, and good advice it was too, is to start simple and initially stay away from the cheap mass produced stuff. They are so built down to price that they are throw away and not ideal candidates for repairs. Good for pulling apart to see how things work but then difficult to get working right again.
my suggestion would be to start on an old mantle type, time only or time and strike. Plenty of Smiths out there for low money and once inside the movements are solid. I was given a Smiths Westminster chime and it’s a lovely old clock. The chime setup is complicated and with three trains to work through it takes time to figure it all out.
Take photos, lots and lots as you dismantle everything. Keep the different trains separated placing each cog run into their own containers to avoid mixing them up and if you can number or mark the order of each train.
There are some top guys on here who will help when things go wrong (and they will go wrong) but when the thing is right and it starts ticking it is the greatest satisfaction of knowing you did that.
good luck and keep us informed
Hi Steve    Wat Sqiffy has said is sound advise keep it simple until your confidence grows. Th time only mantle clocks (one hole in the dial) are chunky enough to play with only the suspension and escapement  are breakable the rest is quite tough, please mind the mainsprings and be sure to remove the tension before undoing the plates as the un tamed power when released can damage the clock and make more work. Take care and be patient as the cock up gremlins are sure to turn up.
If you are going to start on clocks, get yourself a timepiece only. If you want to start with a travel clock, get a Europa alarm. They are easy to work on and if it needs re-bushing you can buy the bushes readymade. You will need a staking tool with punches, just knock the old out and tap the new in.
Thanks guys, I've done a few watches, and I hardly ever break them now [emoji16]. I've been enjoying servicing old Russian watches, cheap and cheerful. But I was curious to see how different clocks are.
I just took a look on the bay at Smith's they look great. There's one listed close to me (so cheap postage) and only $aud20. It's listed as a mantle but the winding key is at the back not on the face?
That is a 30 hour. Here is a photo of the balance wheel and how it is held between the two oil cups. It already shows you how the hairspring should be, also how it is pinned. Three things can go wrong with this. 1 The hairspring can be mangled up, 2 the balance pivots can be worn and need to be put into a lathe and re-pointed with a small Arkansas stone. Picture a blunt pencil then turned into a sharp one. 3 The oil cups can wear inside and need to be re-placed or with the right drills cleaned up.
You cannot re-bush the movements the plates are too thin. I know the photo says alarm clock balance. The clock movement in what you are going for its the same.
At some point, you will need a lathe for clock repairs. Not all of these movements do you find the balance pivots worn. I was just pointing out the major problems that can happen. It might be a good thing to look out for spares; years ago, you could buy a box of replacement staffs. One way to stone the balance would be to hold the staff in a pin vice, rotate it while stoning. I have never undertaken such work in this way.  A few practice runs on steel pins would be a good start.
2 hours ago, SteveT said:
I don't have a lathe is it still worth doing. Hmmmm I'd like a lathe emoji6.png
The lack of a lathe will eventually give rise to problems as the lathe will allow you to do parts repairs/manufacture which will inevitably be required. But you will by that stage be getting to serious levels and the investment would then be worth it.
Also consider the work that will be done is on a small scale so an industrial sized lathe will not be required.
All clock repairing that needs a lathe can be achieved on a Unimat 3. It can handle long case clock barrels and the centre wheels. They do not come any bigger than that. I don’t think for one minute you will be undertaking Turret clocks.
On 4/22/2019 at 10:57 AM, Deggsie said:
Goodness me. I do hope those little electrons at Tapatalk don’t continue to misbehave and randomly insert non horology related photos. emoji12.png
Why Tapatalk? The software that powers the forum has excellent support for mobile browsers. Just try, I think you'll like it.
Hi JDM. You’ll have to ask JohnT as to why he uses Tapatalk. [emoji6]. If you don’t understand, maybe you’re not seeing the full pictures we see on Tapatalk. Oops!
Is it possible for somebody to remove this topic and preserve the young lady’s modesty? I’m as warm blooded as the next male, but I feel this isn’t the place for such photos, accidentally placed or not. Deggsie
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
    • Haha. You're just in a wicked mood today John 😅
    • Heres my watch of today, a Smith 13'" RY . My missus bought me this for this Valentines day a bargain 14.99 with a reduction, the seller has occasional 20% off offers now and then so it was about 15ish with delivery. I love Smiths and i love bulleye dials, this is my first one. The watch arrived non working as stated and i knew what was inside and what would be against me, but i enjoy a challenge, we dont expect a lot if anything from pin pallet movements. A balance pivot was broken and i didnt have another staff but i did have another RY with a battered dial so i robbed the balance and tweaked it around to make it work apart from that mostly just a good clean and relubrication. Keyless works are pretty rough by design and the crown is a bugger to get in and out with the dial on, the setting lever hits the dial before it releases it, so a little mod is needed to help that along. Major problem was the pins on the lever were quite worn which make the old tg have a snow storm fit. Its a similar read for most pin pallets, these were brass as was the escape wheel. But perseverance is me, i didn't change the pins but i did spend some time dressing and polishing the worn areas which improved the trace a lot with some straightish lines 😅 and a beat error of .5 . Not sure what the lift angle should be on these and i Wasn't in the mood to work it out and who believes timegraphers anyway, but at the default 52° it runs with 260ish full 210 after 24 hours dial down , the verticals rates were pretty much all over place. So lets just put it in it's superlight aluminium case and see what happens. Been wearing it now for 3 weeks and it's consistently losing around 1.5  minutes a week winding each morning i think pretty good for an old pin pallet watch. I just love this dial, thanks wifey heres my Valentine's gift for yer sweetie x
