The postman's called
Johnnie
Hi all, the postman has just knocked with my latest purchases ! Each owing me the sum of £3.27 each including postage. The pocket watch is a "runner" but I haven't got a clue what it is, or was before the case went missing? The Oris looks ok, but the balance spring is all over the place, and the Rondamatic also looks clean but again the balance spring is total mess! More like a rat's nest.
PS, any idea how to remove stem and crown from the Rondamatic? The silver button and the indent either side of the stem does nothing, nor the screw, I am stumped ! The balance spring appears to be glued??? And is wrecked I think.
So far as I recall, you press the silver button to the right of the stem in the picture. I can't be certain which position you need to be in, but I think it was the wind position.
The hairspring... 5 minutes and you will have that sorted :P
It does look unfankleable but you will have your work cut out. The real question is why is it mangled in the first place. Has something jammed up and "bounced" the spring out of the side of the balance, or is this simply the result of fat thumb trouble on the part of the previous owner?
Hi Andy, the previous owner of all the above watches has had a go at them all ! He said, " the Rondamatic was running fast and the Oris was slow, so got his mate to adjust them and they both stopped" ! Can't imagine why lol. I will try your suggestion about the stem removal. They were cheap and ideal for me to practice on, and the bonus is I know out there there is someone worse than me ! Thanks Andy for your time and advice.
No worries. The Oris balance is probably saveable. The Rondamatic may need a new balance (which are available), but if you want some practice, you might take a crack at fixing that hairspring.
In this case, I would suggest removing the hairspring  from the bridge, by unscrewing the pin screw then taking a good long look at it under some good magnification in good light to try to figure out what origami skills you will need to bring to bear. When the hairspring damage is less severe, i tend to leave them attached to the bridge and work on them in the watch. The "correct" way to do this involves some tools that I don't have, but in most cases you can get by without.
If it proves too damaged to sort, then you will at least have learned a bit about the noble art of hairspring massage. I have given up on a few, as sometimes they simply snap when you try to un-kink them. You win some, you loose some.
If you do get it back in order, or even if you decide to replace it, the original problem with those two watches still remain. Most likely they simply need a good clean and service, and once adjusted they will be ticking away like new.
Again I will take your advice, the Rondamatic is twisted badly and as they are available I will go down that route. The Oris, I will try to sort out, have looked at Mark's YouTube video on sorting hair springs so will give it a go, nothing ventured nothing gained. Many thanks.
The Rondamatic movement is numbered/cal 1239 25jewels "Grovana watch co" I have tried Cousin's as they do stock Ronda parts, but they don't list 1239 ! The Oris is marked 233-68E  and I can find very little on this either. If anyone has any ideas as to where I can look I would be most obliged. Everything I have done so far has been on Seikos and you can get most things readily, in fact in a greengrocers!  Now I realise that when my dad used to say "your problem is you just don't think" he was 100% right lol
Ref Rondamatic, it appears that the hairspring is glued, is this a special glue ? It is green and due to my very limited experience I have not seen hairsprings glued on. Any clues as to where I may get another spring balance from would help. As said I have tried Cousin's and eBay, Cousin's and eBay were brilliant for the Seikos that I have worked on but not much help concerning the Rondamatic. I am hoping that it's simply that I am looking in all the wrong places. Many thanks in advance.
100% right. Crown in winding position, out it came easily. I had it pulled out ! Easy when you know how. Many thanks Andy :)
Well.. pretty pricey, but here is one. https://www.ebay.co.uk/itm/RONDA-MATIC-cal-1238-automatic-swiss-Movement-Spares-Parts-Choose-From-List/143133641422?hash=item21536e0ace:m:m_WopSwuG21zF7L8oRXtoMg
Seller is in Poland, and the postage is steep, the part is more than you paid for the watch, so you would probably be better keeping an eye out for a better price, or even a whole mechanism with good balance. I suspect you could pick up a beat up, scrap ronda automatic for <£10 if you are prepared to keep checking every few days.
.. or you could try unfankling the current one.. what could possibly go wrong. As to being glued, it is probably shellac and would probaly dissolve in nail polish remover (acetone), or possibly denatured alcohol or perhaps isopropanol. I pretty sure the one I have is held in place with a screw, but it is not to hand, to check.
Hi,That HS is good to practice on. I recommend flying each wheel with new HS.
You got to first get them runing before you get a chance to diagnose the fault the led the mangler ruin them in the first place.
The Oris movement is a ST caliber. Google ST96 ranfft.
Regards
Hi johhnie,  FHF produced 96 caliber as well, ranfft is always helpful.
What I am trying  saying is, the sorted out HS never gets to be as good as new.  Your  Oris for instance looks good enough to get reconditioned and  join your collecrion, certainly not with an imperfect HS. It is not a question of your competence rather the fact this HS is not worth all the work involved.
Parts for FHF or ST are available. If the prices turned out outrageous, I,ll dive in my bag of tricks.
Regards
2 minutes ago, yankeedog said:
the oris looks like france ebauche.
Very true ,Oris and FE look very much the same, if johnnie was HS ,Oris would be a close fit. Not dirct fit yes can be fly to resonate the ribht fit.
Now that a part is found ebay there is no need to fly one
France ebauche ! I am a bit confused.
FHF96 and ST96 or FHF-ST 96 both made caliber 96.
Yankee said the Oris look like france ebauche"  many movements look somewhat similair. I am sure you can find other movements that look similair to what is in your oris.
It should say somewhere on the movement.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
