6498 clone shock spring problem
Hi to all,
I recently acquired a 6498 clone movement (Corgeut watch) to play with while watching Mark's videos and broke the top balance shock spring. To my surprise it was not a Incabloc spring but something like a KIF TRIOR or similar. I am attaching a picture.
I bought an assortment of shock springs from Cousins but the closest one I found was just a bit bigger than the original and does not fit. I am attaching a picture of the original and the new one.
Any ideas what this spring is and where I can get one?
Thanks
I bought a 6497 clone, too, and at my first try the upper spring flew up and got lost. This one had a standard Incabloc shape ("lyre"), but of slightly different dimensions. So, it did not fit. To my chagrin I found out the there is no market for clone replacement parts. And clones are not really 100% identical to ETA original. For some unknown reason they made "improvements" or just imperfect copies of some parts. The clone, being so inexpensive, they want you to buy a new one rather than trying to make repair.
On my Seagull I found a way, imperfect but Ok for practice, to use a standard Incablock lower spring. It's smaller but it can be carefully maneuvered into place.
I purchased an assortment from Jules Borel which did work in the Chinese movement I had at that time.  Later another seemingly identical movement with engraved (stamped) plates came with regular INCA type springs.
The great thing about standards is that there are so many from which to choose!
I wasted 30 minutes trying to figure out why the going barrel from that stamped plate model wouldn't work in the smooth plate variety.  It had different teeth!
Here is a pdf with some size data.  Hope it helps.
KIF shock springs.pdf
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
