Fixing loose pallet fork jewel
I have a loose jewel, as per the title. It's only a spare movement, so I don't want to buy a replacement fork.
I don't have, nor have I ever used, Shellac. It's not a route I want to take just for one jewel.
The question is, what else can I use to re-fix the jewel. Superglue maybe?
Edited by ftwizard
Hmm, not sure if you want to be told you can use super-glue? One stick is £7.30 from Cousins UK, I don't think that would break the bank.
A palate fork jewel requires a special tool to hold the palate fork in place to heat the palate fork and melt the shellac. I have replaced many impulse jewels and have made a few videos on YouTube on how to do it. Search for jdrichard01 on YouTube.
I am very new to this watch repair malarkey, but, I know that knotting compound, for painting on wood prior to priming, is made up of shellack suspended in alcohol. I would try to daub the pallet jewel with this knotting compound. The alcohol will evaporate very quickly leaving the shellack holding the jewel in place. I'd probably daub it several times using a very fine oiler. If there is someone out there who thinks this is a bad idea, please tell me and kindly explain why. Best wishes, Mark
buy a vintage pallet warmer from ebay or you can use a bluing pan or tin over an alcohol lamp. I highly doubt you will be able to use the existing shellac since the jewel is already loose, its not like your just making an adjustment, the damage is already done. but i would say its worth a try. i think the issue your going have with knotting solution is holding the pallet jewel in place for 15-20 minutes, which is how long it takes for the solution to dry. if its dries in the wrong spot you will be back to square one. Plus the consistency of alcohol based shellac is very thin and has no holding power. pure shellac is very thick and sticky almost like honey when its heated correctly and it dries fairly quick.
I buy shellac for woodwork by weight at the hardware store. I don't doubt the friendly guy there would give me few leaves for free. I don't know if it can be used for watchmaking but if anyone wants to try I can mail a small quantity for postage.
is it pure shellac? as in solid form not liquid?
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
