What2buy?
Johnnie
Hi all, first,, my knowledge is very limited and I am about to enrol in Mark's tutorials and I need some sound advice. I have the basic tools etc but feel it's time to invest in a timegrapher and ultrasonic cleaner, there are so many my head spins! Any ideas as to which? would be so helpful to me. Also to any of you that have completed Mark's courses, any tools that were a must have? Many thanks in advance.
And there is my previous answer, making the both of us big duplicate posters :)
I think that you certainly need the timegrapher but not the u/s cleaner. You can clean equally well without one, it may take just a bit longer. I had one and I don't consider it that much important. Beside, isn't recommended to use it with flammable solutions, that is the ones that clean good.
9 minutes ago, jdrichard said:
You can buy a software computer Timegrapher which should be good enough. I bought etimer. Not cheap but really good and all you need is a computer.
Thank you jdrichard, I am off to Google it, when I started looking I didn't realise there were so many out there, and I have ended up not being able to see the wood for the trees ! Thanks again.
You can use the mic part of iPhone headphones as well, plugged into your computer. There are tricks to boost the mic if you are running windows 10.
Not sure what is on main computer, I rarely use it jd, mostly use my Hudl. Will check in the morning as I don't want to wake grumpy up to ask lol. Many thanks.
11 hours ago, Johnnie said:
Hi Jdm, I was looking as to which timegrapher ? I have absolutely no knowledge of them and was looking to being pointed in the right direction. Many thanks :biggrin:
Check pinned thread:
I don't doubt that software based ones are good and cheaper but I like an always-ready instrument on my bench, no fiddling and it gives me with a good stand which makes easy to regulate and switch positions.
Jdm, thank you, having a good read up now. As I know zilch I rely on other WRT say! The apps obviously are appealing money wise and because you have instant access. But having a timegrapher on my desk would be easier for me as our main computer is in another room,,,. And is usually locked in the shopping channel lol.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
