How to extend a sub seconds hand shaft/pivot
Definitely randy, hopefully greed bites them in the ass. -
That sounds like a really good website -
I have a holder specifically for this with thin jaws so that they dont encroach too far onto the dial that i lined the jaws with pvc tape so the dial does get scratched. I'm also aware that the second hand doesn't get caught up. You could also use the plastic or wooden cup style of holder but the movement does slip around a bit in the plastic one. Otherwise i pick it up and manage to flick the stem out while pushing the setting screw or lever, it is fiddly. -
It looks to be plate 1520 and there are 4 with that number but they all take the same torsion spring 0.003” Horolovar. Dell
Something rubbing with the movement of the hands, dial center hole, hands on glass. Motion works rubbing , hour or minute wheel, calander in the process of changing over ?
