Hello from the Isle of Wight, UK
N0bby
Hi everyone!
I'm a mid-fifties chap from the Isle of Wight, and I finally got round to getting a bit of a watch hobby (oh okay, obsession) going quite recently. As a result, I've been buying movements and inexpensive automatic watches, with a view to collecting and modding/servicing them myself. I am just at the very beginning of getting a feel for working on such a small scale.
I really enjoy watching and listening to Mark's videos, and pretty much all I know about the workings of watches so far has been informed by his tutorials.
Today I accidentally amused my granddaughter by replacing the hands on a movement so that the hours and minutes didn't work at all; she christened it "Popsie's Nonsense Watch"...
I look forward to continuing to expand my knowledge on forums such as this one.
Welcome Nobby.
Although I live at the opposite end of the world (Tasmania, Australia), my mother comes from the IoW (Shalfleet) and I've spent a little time on the island.
Take heart, I'm a low level tinkerer who has certainly made things worse in the past, but I've also completed a number of successful services.
Hi and thanks for the welcome. tritto, it's always nice to hear from people living in far-flung parts of the world who know the Island.
I'm thoroughly enjoying myself so far, and hopefully my knowledge and ability will build little by little as I aim to reach the "not totally incompetent" level of tinkering.
BTW, I'm determined currently to stay at the "totally incompetent" stage for a good long while, having so far scored 2 for 2 on pulling off the second hand pinion while removing the hands from a movement.
Mark makes it look so easy, removing all three at the same time.
I then read elsewhere (after my second mishap), "always remove the second hand first, and then the minute and hour hands". Yes, I'll give that a try next time...
I always remove the three hands together with a presto tool, only once in many hundreds I got the second hand tube separated. That, I think, would have happened even if used levers (as Mark does), or pulled the second hand alone, because the force is on the same point anyway. By simple logic, that should be the case even if the pinion separated from the wheel, but with the small parts and forces involved it's difficult to tell for sure.
jdm, the unfortunate thing in this case is that I went ahead with the levers, broke the second hand pinion, and then a little later found the presto tool that I'd bought a couple of weeks ago and had completely forgotten I now owned.
Which points to another thing I really must do - get my tools properly organised!
    • If frank says these bombè jewels are for balances and similar pivots then they are used cupped side facing the pivot and then capped i assume. In Nicklesilver's reply i guess that cup can also be reversed and used as an oil reservoir leaving the shoulder riding on a less frictioned domed surface. 🤷‍♂️ Hence the use of them on wheels closer to the escapement that have less torque requiring efforts to reduce friction and are also uncapped.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.  Same answer as Mike regarding the dial, its often just a slapped on name of a retailer but i thought you were way above this understanding Pete ?
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
