mainspring installation help
I am going nuts trying to install a mainspring into an Elgin 16s barrel.  I haven't done a mainspring in 20 years and I don't remember having any problems before but this one is crazy!  I've gone through it several times and each time the t end on the mainspring winds up some distance from the slot in the barrel no matter how carefully I line it up, no matter even if I make sure the t is engaged into the slot before I push the release button on the winder.  Of course, once it, I cannot shift it to line up.  What in the world am I doing wrong?
From your description it sounds like you're doing everything correct except? Then for anyone reading this Elgin 16 size mainsprings are typically T brace. So you wind it into your mainspring winder leaving a little bit out. Put all of that into the barrel line up your slot with the T. Make sure the T is in the slot you'll have to push down to do that. Then you have to hold the T in place otherwise it jumps out. Some people use the end of their tweezer I usually use my large screwdriver. Because if you try to push the spring into the barrel without holding the T in place you will discover as you have it will not stay word supposed to be.
Thanks John, that's more or less what I had to do.   Funny but I don't remember having this problem before but, then again, I don't remember many things these days.  And it doesn't help that my hands now shake badly.  Perhaps I should move on to clocks?
    • Ok thanks Ross, I will give that a try!😁
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
