My 2824 dive watch project
So I started by choosing a Chinese ETA 2824 clone movement, dive-style case, dial, hands, and bracelet.
In another thread I posted my travail about getting the dial to work with the movement.  I ended up having to order another dial.
Today I had the new dial & hands attached, and placed in the watch case along with the movement ring.  I put the new crown on the stem, and measured how much to trim off the stem.
Well, NATURALLY I cut the stem too short.  Honest to God, if there's a mistake to be made then I don't think I've MISSED a single one.
I keep telling myself that this is my first project, and just like pancakes the first one is always a throw-away.  But MAN this can be frustrating.  I mean, Mark makes it LOOK so easy...
The good news is it's just a cheap Chinese clone movement.  I can get another for $40 US.  Or I could just order ETA 2824 stems for $5.00 a pair.  I mean, what are the odds that a genuine ETA stem WON'T WORK with a Chinese clone movement?  :rolleyes:
Shoulda started with an ETA 6498...
Chances that the stems you purchase are gen ETA is very unlikely and if they are gen, they will work just fine anyway.
Cutting stems too short was a particular favourite of mine when I started. I cut them too long now :biggrin:
Be careful of the stems you order.   I went through roughly the same scenario and feel your pain!  Ruined an already bad dial, got a replacement which wasn't too great either!
As for the stem.  What length do you need?  Mine took longer than the standard 16MM and 20MM proved very hard to find.  This guy claims to have 20 MM stems in item number 254163508849 on the auction sight.  I purchased some claimed to be 20 which turned out to be 16.  Some I sent back, the overseas ones I kept.
If you can use a 16MM stem, PM me and I'll send you one.  Got several in my efforts!
Phydaux,
Welcome to the learning process. I would bet that Mark went through the same experience when he was starting out. After somebody puts in  years of study and practice they seem to make the process look easy. In truth, it isn't. As mistakes are made one learns techniques and tricks to avoid repeating them. I cannot count the number of watch parts that I launched into a low earth orbit that evaporated somewhere between the ozone layer and stratosphere. When starting out, expect to break things. Practice on the LEAST expensive  movements you can find.  In the beginning it doesn't matter if the movements even work. Just famillarize yourself with the components, where they go and how to  disassemble, clean, reassemble and lubricate. If you start out with non working movements you will also begin to recognize why the movement failed to work.  Anybody who is honest about it will admit  going through the same learning experience. Relish mistakes as an important part of the learning process.
david
Edited by david
4 hours ago, nichod said:
OH.   When we get it all figured out I found this earlier this AM:
143143823544
Makes my credit card twitch!  It would probably rate an SW200 movement!
I don'r know what that is suppose to be...
I don't know if we adequately addressed your question about whether or not the stems would fit your movement:  The Seagull type movements (ST2130 is what I used) WILL take a regular 2824 stem.  If you paid $40 for a movement, you may have something different!  Carefully look over the pictures on ebay and you should be able to judge.  There are lots of 2824 stems listed, but most will probably be too short for a custom screw down crown type fitment.
Good Luck!
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
