Good steel for staffs
Am looking for a source for good steel to make staffs from.  Got some from Esslinger recently and it appears to be crap.  Way too hard and won't anneal (at least I can't do it).  Any suggestions for where I can obtain it.  I'd like a range of sizes from, say, 0.5 mm to 3 mm.  Following link is the stuff I got from Esslinger:
https://www.esslinger.com/staff-and-pivot-watch-and-clock-wire-rod-assortment-blue-steel-55-1-93mm-12-pieces/
Industrial suppliers such as MSC, McMaster Carr and others sell different grades of drill rod. The most widely used for watch pivots  is water hardening drill rod. This does not mean that water hardening steel is the "best" material, only that it is the most widely used.  The three most commonly used types of drill rod are water hardening, oil hardening and air hardening. Water hardening drill rod is the least expensive and air hardening is the most expensive. As air hardening steel is subjected to the least amount of shock from heat treatment, is has the most dimensional stability. This is why it is used for dimensionally  critical parts such as blanking and piercing (stamping) dies.  Since the making of watches began long before the invention of modern steels, water hardening steel is still used because it was formulated first and established a tradition.
A watch pivot should be made to the correct dimension (@ 1/10 of a millimeter) and reasonably hard (@Rc 50) to resist wear. If it is much harder than that it will transform from spring hardness to wear hardness and be more subject to breakage.
I went through a lot is experimentation to finally successfully turn something that small in diameter.  I would turn the pivot down to about .010 inches and then watch it snap off when I tried to machine to a smaller diameter. The goal was about .004 inches in diameter. I think most people would turn it down to .010 thousandths and then grind it down the rest of the way in a Jacot tool. Instead of taking that route I set my watch lathe up with high precision dial indicators and fed the cross slide in using very small increments. I also used a carbide cutting tool.
david
The above mentioned assortment is probably that from India. The kind of steel is absolutely unknown, the Indian exporter does not give any details. Such an item I would buy from a source only that will give technical data, too.
Frank
  • Similar Content
    • The entry jewel's not as bad but seems still too much lock. I do epilame the escape wheel and pallet jewels, then run dry for about 15 minutes, then put 9415 in exit jewel very little at a time and check with backlight how the oil's distributed.  Another question is about capped escape wheels. Should I somehow wear the epilame off the pivots before installing the wheel? I normally let the escape wheel run dry for that said 15 minutes when there's no cap jewel.
    • Sometimes there's a certain place under the bezel where the case knife is supposed to be placed. In this borrowed pic there's a small crack at 3 o'clock.
    • Hi my fellow forum addicts, I'm writing this as I seem to have a hole in my knowledge (probably one of many!) I seem to have a horrible time removing bezels from watches. I am talking about the rotating type on sports/diving watches. I see many videos where the guy on screen barely inserts the case knife under the bezel and with no effort it pops off easily, then at the end it clicks back into place by hand with no effort. I am sure that part of this is due to skillful video editing, but I seem to wrestle with them, I have tried case knives and  even when using the tool below, I tighten it up in several positions and nothing happens. On a many occasions I have even warped the bezel in my attempts to remove it. Similarly, I have issues replacing bezels after cleaning etc. and often they have to be replaced using a press tool and inevitably are far too tight and will not rotate or loose to the point where they fall off or loose their click (perhaps due to micro warping when I tried to remove??). It is now to the point where I am actually avoiding watches with bezels as my success rate with them is terrible......please help!! In short I am asking: What am I doing wrong? What is the best method for removing bezels - how do you do it? What is the best method for replacing bezels - how do you do it? Any tips or tricks? Thanks
    • Amplitude still seems low, but I'm going to let it run in a bit and revisit. Meanwhile, got the first layer of the calendar works together and made sure the date ring snaps to both in quickset and regular setting. The mechanism is pretty cool, so I took a video.
    • This is the part that need replaced if anyone can point me in the right direction.
