Help determining what movement/dial I can fit into a case I have?
I have wanted learn how to assemble a watch from parts for a while now and after recently breaking the second hand stem(is that the right word) on my favorite watch I figured I would give it a go. The watch repairman said that the movement would be expensive to order and that two of the dial post were broken meaning that even if I ordered it in I would not be able to properly attach it to the existing dial.
After expressing a desire to learn more about watch repair and mentioning I had recently purchased a repair kit and had been watching videos he went to the back of the store and handed me a bag of vintage watches I could practice on(including a Hamilton) and wished me well.
Due to the sentimental value I would love to try and find a movement and dial that will fit inside the existing case. As pictured below I have all of the parts to the watch including the plastic moment ring. I think that the broken movement is a Technotime. Under where the watch battery would go I see numbers that appear to be 71205, but googling that brings nothing up. The watch itself was an alviero martini pc 7030 but google was unable to find any info on the movement. Other than that it just says 7 Jewels and swiss made.The case has a diameter of 38 mm. Ideally I want to be able to find a cheap quartz movement(to learn with) or potentially a small automatic movement if it will fit that has blank dials available for it. Here is a link to the parts I have as well as a picture of the Hamilton I was given if anyone can ID it. If Daniel Wellington can slap a cheap quartz movement into a watch I figured why can't I!
I find that hard to believe even swiss quarts movements are pretty affordable
https://www.esslinger.com/eta-watch-movements/
Keep the dial if you find the right movement (or a equivalent replacement) you can use dial dots to attach the dial
If you can post a better pic of the movement maybe someone here can identify it
ok the alviero martini (italian fashion designer) watch is basically a fashion watch, which means that movement could very well be a technotime which is french, and italians notoriously do outsource to france for many things from clothing to cars. most fashion watches arent always made using swiss movements, the one ive seen use chinese movements.
first things first:
-measure the diameter of the movement (Use ligne size - take the mm and convert to ligne on google mm-ligne converter)
-measure height of the movement from top of the center pinion where minute hand attaches (use mm)
-measure stem height from bottom side of movement (dial side) to the middle of the hole where stem goes (use mm)
then go to esllinger.com and get a Harley Rhonda quartz movement that fits the measurements you just took. they are fairly cheap from $8-$25. also you will have to measure stem length and cut accordingly so crown will lay flush to side of case when seated (do not use the old stem as a reference outside the case) you can install the old stem into the old movement and the measure the length that it sticks out, then cut the new stem at the same length when its installed in the new movement (dont do this until you find the correct crown) because you may possibly need a new crown to fit the case and thread onto the rhonda stem. measuring a crown with a caliper can be difficult because its hard to measure the tube height and diameter. you can get an assortment of crowns from esslinger as well. the old crown may fit the threads so try that first. as far as dials go for the rhonda there are many to choose from.
While it's common knowledge that Italy has not produced any watch movement since the late '70s or early '80s and even back then just very few basic ones, I'm not sure what do you mean with "outsource to france". Italian cars (FCA) are actually either made in Italy, or in other EU countries, but not in France, and vice-versa. Italian mid and high-tier clothing is still made in Italy, and as such indicated on the label.
About fashion watches the strongest mov.t supplier  are actually the Japanese, interestingly SII and Miyota (Seiko and Citizen respectively) mechanical movements are actually made in Japan, but these are used on micro-brands, not fashion.
that is true, now, since there has been an economic trade war between the two since the late 80s but has recently been ramped up, but not before and sometimes in between when agreements are made.
lamborghini at one time were assembled in france but not since audi owned them and they are now made in italy, since germans outsource vehicles to italy such as porsche. bugattis are assembled in france as well. armani exchange has clothing made in france. higher end brands like Gucci YES are made in italy, but most of lower end brands as you know outsource same as america, it cost less
Wait.. I'm not a car buff but for the record:
That being said, of course Italian industrialists, like any other in the world, routinely outsource or relocate factories to the place of lesser cost. With all the socio-economics consequences, one of which is that very many (Italian and other) renowned brands are now foreign-owned.
11 minutes ago, jdm said:
Porsche never built anything outside of Germany  https://www.porsche.com/international/aboutporsche/jobs/profile/locations/
Just as a curiosity I once in my lifetime worked in the automotive industry and if I don't remember wrong I once went to Finland to see how the Saab production went.
And at least then Valmet was talking about building Porsche Boxter and Cayman in the feature line .. and I guess they did between 1997 - 2011 when the production was moved  to Magna Steyr in 2012.. one should never say never as Bond said ;)
https://en.wikipedia.org/wiki/Valmet_Automotive
    my jeep has an Italian engine - real crap.   vin
  Valmet has turned out some very good stuff- thru the years  in Finnland.  vin
idk where your info from but i own a porsche 87' 911 turbo and every part i ever bought for it says "made in italy" lol
Which parts and where are you buying? Italy is still a big manufacturer of generic automotive  parts.
pretty much every part i have ever bought from center caps, electrical, moldings, body panels, etc. they may be assembled in germany but parts are manufactured in italy.
Surprising if these were original parts from the dealer, even in the time they were still made for an '87 model year.
The reality of the Italian automotive industry is that it depends almost entirely by FCA, and the entire segment is struggling.
    • Got another one today! It took 10 weeks, but finally arrived. Fairly complete but I added the pivot guage. The burnisher and bow came with the tool. The case is a bit rough and the tool pretty dirty, but trying to decide how much I want to restore.
    • OK, so long story short, I'm working my way through Mark's courses using a "Sea-gul ST36" (or ST3600 from some vendors) AKA an ETA 6497 clone. as a practice piece.  I've had it fully appart and cleaned it, and have had it fully back together an "running", but only briefly as my oil hadn't arrived at the time.  In the course of that work, I saw no markings on the movement that would tell me if it was a true Sea-gul or just a clone of their clone of the original ETA movement. Well, fast forward to this weekend, when my oils arrived in my mailbox and I sat down to try my hand at oiling.  Everything was going swimmingly until I got to the shock setting on the top of the balance cock.  I was able to open the lyre spring without issue, but in attempting to swing the open to access the cap jewel and chaton, I apparently accidentally pressed the launch button as I sent the lyre spring into low earth orbit.  Like most things that make into such orbits it came back down at a place not too far from where it started, but of course that also means that it is no longer in the setting. So my task is now to get said spring back into setting.  What I have read so far tells me that I seem to have two options: Another thread here seems to indicate that the spring came out without taking the balance cock apart, therefore it should go back without the need for that procedure.  That seems a bit pie in the sky for me, but the posts in said thread also gave some high level information about how to get the spring back in (putting it at an angle to the channel cut in the cock and canted so that the tabs fit in the slots, followed by some "wiggling" to get it turned around the right direction.)  I've tried this a couple of times, which have lead to more trips to low earth orbit, but with successful recovery of the orbital vehicle after each trip.  This thread also suggests that what I did to cause the initial launch was to push the spring "back" with more pressure on one side than the other, which put it under tension and caused it to deform out the slot either on one side or at the end (where there is apparently no "back stop".) The other option appears to be varying degrees of disassembly of the balance cock.  Some things I've read suggest that the whole shock setting needs to come out, while other threads here suggest that I only need to remove the regulator arm and the arm carrying the balance stud.  After the last trip the spring made, this is seeming like a better option, but I'm super short on details on how to do what needs to be done.  if I am following correctly: I need to loose the balance spring stud screw so the stud is not held in the arm. I need to somehow disengage the balance spring from the regulator (all the regulators I've seen in videos look nothing like what I see on the balance cock I have.)  What I've seen on the interwebs is a couple of "pins" that the spring passes through.  What I see on my assembly is something that looks more like a single pin with a "V" shaped notch cut in the bottom of it.  The spring is secured in that notch with something that I guessed was glue, Posts here suggest that on some of these movements glue is in fact used.  So I'm trying to figure out how to tell, how to soften dissolve it (I'm guessing IPA or acetone) and how to put it back when I'm done (superglue?  UV glue?) With the spring detached from the cock, I've read that the regulator and stud carrier are basically glorified C clamps around the shock setting and that one removes them by slipping a razor blade under one side of each and prizing them up.  I assume that they go back in the reverse manner like another C clamp, but that again is only a guess.  The place I got this information from seemed to leave that bit out. Once I have one or both arms off the shock setting the above mentioned post seemed to indicate that I could just slide the spring back in the slot, though again, I'm interpolating between the lines I read.  The alternative that I've seen demonstrated on high end movements on Youtube is to remove the entire shock setting and to replace the spring from "underneath" rotating the setting so that spring basically falls into place. I'm not anxious to try this method, as I don't have a jeweling tool to put the shock setting back into place.  That not to mention that the professional watch maker who did the demonstration described "fiddly work." So at the end of the day I'm looking for a little guidance on which pathway to follow, or if I've missed something obvious, a new direction to follow.  If this is a repair that just need to wait until my skills improve I'm totally good with that, I can get another of these movements in relatively short order, I just don't want to treat this one as disposable, and I do want to make an honest effort at fixing it and learning from this experience. Thank you in advance for reading my ramblings and for any suggestions that you might have!
    • All the best, family always comes first, and I believe you have made the right call that you mother deserves your full attention. However, when you need a little outside distraction the guys here will always be available for some banter or a heated discussion on lubrication 🤣.
    • Wire for what? if it's steel then only certain types of steel can be hardened ie high carbon steels: "Mild steel doesn't harden very well. It doesn't have enough carbon. Get something like O1, silver steel or if you want to go full watchmaker, then Sandvik 20AP". Source
    • I'm wondering if there's any specific type of wire I should get for hardening? I would assume it doesn't matter as long as the wire doesn't melt before it is at temp.
