More Mystery Tools...
JBerry
Hey Folks,
Was picking up some tools yesterday from a friend, can anyone advise me on the below?
  • The first is surely a Jacot tool, but have no idea on the brand or additional functionality...
  • With the second Mimo tool the top metal piece freely rotates on the base, but for what reason?
  • The third is obviously a drill press, but does anyone recognise what brand it is? no markings on it...
  • The fourth was just a handful from a huge bag of these...
Thanks very much in advance! My friend is trying to clear out some stuff and doesn't know where to start.
Edited by JBerry
Top one is definitely a Jacot tool, a very expensive one, its possibly meant to have a diamond lapp wheel to polish the pivot a bit like this one.
http://cdn.webshopapp.com/shops/36767/files/150953315/sold-bergeon-4106-rollifit-with-steiner-jacot-pivo.jpg
No idea on the second one
The last one what is the metal they are made from and how big are they?
I am wondering if its a bag of anodes for plating.
Thanks for the reply! To me they looked like Lead, but they were too light to be, so I'm not certain
A quick test would be to weigh a number of them and then fill up a measuring jug with water and drop them in.
You should be then able to work out their volume by how much water they displace.
Nickel weighs 8.908 grams per cubic centimeter.
Lead weighs 11.342 gram per cubic centimeter.
Tin weighs 7.265 gram per cubic centimeter
Also if they are tin and you bend one you will hear a cracking sound as the crystalline structure within the tin cracks, lead won't do this.
If you are accurate enough with your weighing and measuring and they are not an alloy of elements you should be able to work out what they are made from.
Edited by Tmuir
Are there any symbols or marks at all on the Jacot? I'm 99% certain it was made to work with the straight burnisher and not a wheel, there were also automatic burnishing machines using straight burnishers quite similarly by Hauser and others. The general look of some of the components says Steiner to me, which would be a rooster symbol if not marked with the name.
I didn't get a great look as it, but I didn't see any marks on it. Is the tool driven by turning the black knurled knob on the right hand side?
As I understand it when the burnisher is moved front to back it causes the drive wheel to turn which moves the pulley which engages the part.
16 minutes ago, praezis said:
I think you are right, will look up my catalog later.
Frank
Do you have an old catalog? I have one from the 50s-ish (I think), which doesn't show anything similar to this, but it's old enough that the Jacots are still the old traditional style and not Steiner's later distinctive design. It's be nice to see something from in between when mine was printed and now; I'll get mine scanned and post it up somewhere too.
The bottom items look like cut floor brads a type of nail used for nailing floorboards down, flat to prevent splitting as they are hammered into the floor board.
Ding ding! You got it, knew I had seen them somewhere before
Sent from my Redmi 4X using Tapatalk
The last one looks like old nails, tho these are bran new, you might find some if you take off a back of a longcase clock or any very old antique furniture, and as Vinn3 said also used on timber floors.
JD Berry,
It looks like you hit the mother load. The tool in the first photo is expensive and almost impossible to find.  If you watch this video you can see a similar  tool in operation:
https://youtu.be/mkGygB7BMsQ
The tool in the second photo looks like a set of dies and a holding base. It would be used in conjunction with a press for pressing in watch crystals and backs.
The tool in the third photo is a small general use drill press. It is good for drilling applications that do not require a high rate of speed. Extremely tiny drill bits will break if turned too slow. I have a Dumore high speed drill press that turns at around 20,000 rpm and is suitable only for extremely small diameter drill bits.
david
1 hour ago, david said:
J Berry,
You should suggest that your friend moves the tools to your home.
david
Tools/parts have priority over food/clothes, still managing to keep shelter above that for now... ;)
I did pick up these beauties, half the worlds supply of bows and crowns, pallet alignment tool, some new books and an escapement model I now have as the center of a shrine in the house.
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
