Solar Pocket Watch
I have a Solar pocket watch with the seconds at 6:00 that needs a new balance staff.
I cannot figure out how to take the movement out. I removed the case screws and the stem and thought it would just drop out but no such luck.
It appears that the main plate is larger than the back of the watch which seems to be the only removable part.
There must be a way to get it out but I can't see it. Please let me know if you have had experience with this type of watch.
Thank you
I don't know this specific brand but I have worked on a few where the movement comes out of the front and some don't have a very obvious case separation ring like the back does with an indentation.
Does it have a decorated or plain but slightly raised ring between the crystal and middle of the case body?
I have an old one in my drawer upstairs which may be similar that I can snap a photo of if it might help you?
It does have slightly raised and decorated ring. There must be a separation somewhere but I can’t seem to find it but there has to be one.
Does it separate at the raised ring?
Apologies I didn't get back sooner.
I'm assuming there's no obvious hinge or lip for a case back tool.
I'd suggest first trying to unscrew it, rubber gloves can be handy here for grip.
I'll get a pic of the one I have when I get home from work, while not exactly the same it might give an idea.
Logic says if it won't fall out of the back it has to come out of the front.
48 minutes ago, Folkvisor said:
I got the front off. I used a very little penetrating oil on the rim and it came off quite easily.
Thank you for pointing that out to me.
Now to see if I can do something to make it work better.
Great news. I was curious because, although that's typical there are always oddities out there.
The ratchet wheel screw is extremely tight. I can't remove it. I tried to loosen it a bit by putting on a little pallet jewel oil and letting it seep in under the head of the screw. Hopefully it will loosen it a bit but I am not certain it will penetrate far enough.
I don't want to force it so much I break the screw.
Any ideas?
Any ideas?
I'm not sure other than perhaps try a little diesel or plus gas, (you can buy it in tins so you can just put a drop on).
Highly unlikely being the ratchet wheel but have you tried to see if it's a left hand thread?
Go cautiously though. You don't want to strip it.
If it were me I'd use something like a hairdryer to apply heat locally to the screw head and ratchet wheel then plus gas or if you can get a little easily, diesel, it creeps very well on seized bolts and was a commonly used penetrating oil when I worked as a mechanic.
The crown wheel was loosened by turning it cw but the ratchet screw should be a regular thread...I think...
I’ll see if I can get a little diesel fuel. I’ll try the heat thing too.
Thank you for the suggestions.
I promise not to use WD40...
Now the hard part.
Any idea of problems replacing the balance staff?
I've watched videos on this and all I've really learned is that it isn't an easy thing to do.
One suggestion was to use a lathe but I haven't no lathe - just a staking tool.
That one unfortunately is way out of my skill set.
Beyond using a staking set to drive out and press in a pinion, (which I've had very minimal experience of) I have no further idea.
I imagine if fine tolerance adjustment was required then a lathe would be necessary.
I believe Mark covers replacing pinions with a staking set in one of his videos though.
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
    • I bought this box of jewels a few years ago and noticed that the glass containers are divided into two sections. In the first section, the containers have a label with red text colour and always start with the letter B. In the second section, the text on the label is black and lacks the letter B. There seem to be roughly the same number of containers in both sections, and each section has the same sizes of jewels. The only difference is that the jewels in the B section with red text have a slightly rounded, convex underside. My question is what are these rounded jewels for and if I can use them instead of the jewels with a flat bottom if a certain size is missing?
