Solar Pocket Watch
I have a Solar pocket watch with the seconds at 6:00 that needs a new balance staff.
I cannot figure out how to take the movement out. I removed the case screws and the stem and thought it would just drop out but no such luck.
It appears that the main plate is larger than the back of the watch which seems to be the only removable part.
There must be a way to get it out but I can't see it. Please let me know if you have had experience with this type of watch.
Thank you
I don't know this specific brand but I have worked on a few where the movement comes out of the front and some don't have a very obvious case separation ring like the back does with an indentation.
Does it have a decorated or plain but slightly raised ring between the crystal and middle of the case body?
I have an old one in my drawer upstairs which may be similar that I can snap a photo of if it might help you?
It does have slightly raised and decorated ring. There must be a separation somewhere but I can’t seem to find it but there has to be one.
Does it separate at the raised ring?
Apologies I didn't get back sooner.
I'm assuming there's no obvious hinge or lip for a case back tool.
I'd suggest first trying to unscrew it, rubber gloves can be handy here for grip.
I'll get a pic of the one I have when I get home from work, while not exactly the same it might give an idea.
Logic says if it won't fall out of the back it has to come out of the front.
48 minutes ago, Folkvisor said:
I got the front off. I used a very little penetrating oil on the rim and it came off quite easily.
Thank you for pointing that out to me.
Now to see if I can do something to make it work better.
Great news. I was curious because, although that's typical there are always oddities out there.
The ratchet wheel screw is extremely tight. I can't remove it. I tried to loosen it a bit by putting on a little pallet jewel oil and letting it seep in under the head of the screw. Hopefully it will loosen it a bit but I am not certain it will penetrate far enough.
I don't want to force it so much I break the screw.
Any ideas?
Any ideas?
I'm not sure other than perhaps try a little diesel or plus gas, (you can buy it in tins so you can just put a drop on).
Highly unlikely being the ratchet wheel but have you tried to see if it's a left hand thread?
Go cautiously though. You don't want to strip it.
If it were me I'd use something like a hairdryer to apply heat locally to the screw head and ratchet wheel then plus gas or if you can get a little easily, diesel, it creeps very well on seized bolts and was a commonly used penetrating oil when I worked as a mechanic.
The crown wheel was loosened by turning it cw but the ratchet screw should be a regular thread...I think...
I’ll see if I can get a little diesel fuel. I’ll try the heat thing too.
Thank you for the suggestions.
I promise not to use WD40...
Now the hard part.
Any idea of problems replacing the balance staff?
I've watched videos on this and all I've really learned is that it isn't an easy thing to do.
One suggestion was to use a lathe but I haven't no lathe - just a staking tool.
That one unfortunately is way out of my skill set.
Beyond using a staking set to drive out and press in a pinion, (which I've had very minimal experience of) I have no further idea.
I imagine if fine tolerance adjustment was required then a lathe would be necessary.
I believe Mark covers replacing pinions with a staking set in one of his videos though.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
