Plot 2409 part 502 can anyone help?
I volunteered to fix a friends watch, sentimental value, inherited from deceased uncle and all that, and of course at the first opportunity, I pinged the setting lever plunger across the room. I've searched everywhere, to no avail.
So if anyone has the part or a spare movement they can part with, I would be most grateful.
Cheers.
1 hour ago, rogart63 said:
Almost think i have but someone living closer to you maybe have one ? If not i can have a look.
Thanks for your help. I know you've helped me out in the past, and it's very much appreciated.
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
