Timex indiglo light
There is a possibility that the battery contacts are not very clean.
The watch movement would be less likely to be affected by this as it draws very little current, but a higher resistance in the contacts might be enough to stop the light from glowing.
LEDs do fail, but typically last several orders of magnitude longer than old fashioned filament bulbs, but white LEDs require a minimum voltage before they will light, somewhere of the order of 3.3 Volts, and in a watch that uses a 1.5V battery, this is produced by a boost circuit. The circuitry needs a relatively high current, typically 10 to 20mA compared with the tenths or hundredths of a mA, or even a few uA  needed to power the movement of the watch.
Some glowing watches use electroluminescence, and this also requires a voltage boost, and a relatively high current to make it work.
Try carefully cleaning all of the contacts including the presser for the light with contact cleaner or alcohol and see if that helps.
This link might also be useful.
Edited by AndyHull
  • 6 months later...
30 minutes ago, HonorPaul said:
Hi there, Ive just purchased a Timex Easy Reader and the indiglo is not lighting up at the 6 o clock position.
Just wanted you notice that we have a watch repair section for questions, this one should be for  everything but watches so this thread was also posted in the wrong place.
  • 3 months later...
Hi   if the watch is working ok it could be that the substrate of the dial is u/s or insufficient voltage is being applied.     This is a thread which has been docmented beforeon the site. Look up previous threads on the subject using the search window. to avoid repeating ourselves.    Cheers
    is it posible to find a easy way to locate old threads via subject?   vin
Most of what you need is in this thread. The one other thing I would check first, If there is a separate pusher for the light, then I would suspect the contacts on that pusher. Try giving it a clean with small drop of contact cleaner. Also make sure the battery contacts are very clean. The high resistance of dirty contacts may not stop the movement, but it may starve the boost circuitry for the EL light.
If the search function on this site is not getting you the results you need, try using Google with the "site:" verb. Something like this...
wombat site:watchrepairtalk.com
Substitute "wombat" with whatever you are looking for, so for example
In the google search box type..
timex indiglo site:watchrepairtalk.com
This trick works for pretty much any search term (and of course any site, not just wachrepairtalk.com).
See here for even more google trickery.
https://www.google.co.uk/advanced_search
Edited by AndyHull
  • 10 months later...
I do not know if every indiglo watch work the same way, but I recently cleaned up one where the light did not come on. The reason why it did not light up was because an incredible amount of dirt was beneath the crown so the crown could not go deep enough to activate the switch on the side of the movement marked with red. I advise to replace the battery and operate the switch manually with a pegwood/plastic etc so you would eliminate the battery and crown issues.
This is what I found on the web about the light:
"Timex received the patent for the Indiglo® nightlight in 1988. The nightlight's bluish green light illuminates the entire dial of the watch evenly at the push of a button. The dial is coated with a compound of zinc sulfide mixed with copper, a substance which becomes luminescent when an electrical charge is applied. This layer is sandwiched between two conductive layers which act as electrodes. When the button is pushed, energy is supplied by the battery across the two electrodes, which in turn lights up the dial."
More here: Timex indiglo light
Edited by luiazazrambo
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.   I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
    • Don't forget Mark is a hard working watch maker so he is also tied up with work. I'm sure he is keeping his eye on this forum making sure it is running along nicely.
