Elma Watch Cleaning Machine
I know Mark has one of these machines, I recently purchased one myself, and its in dire need of restoring.  I have stripped it down, and wish to rewire it and replace the ageing motor speed switch with a modern alternative, so could really do with a wiring diagram if anyone has one?
Hi Micky,
Have you found anywhere that would sell a new rheostat for the elma? Mine has little to no adjustment on the motor speed anymore. I have managed to set it at a manageable speed but it would be nice to ramp it up during the spin-off.
Yes Mark, found a small alternative to the variable motor speed switch...
http://www.ebay.co.uk/itm/New-AC-50-220V-2000W-Motor-Speed-Control-SCR-Controller-Knob-Switch-/251665634527?&_trksid=p2056016.l4276
Also found complete new machines, one without timer, and another twitch timer for £299 and £399 each, but wheres the fun in that?
Prefer to restore my own.
For anyone interested in the new pieces, see below..
http://www.ebay.co.uk/itm/Watch-cleaning-machine-janta-pearl-brand-cleans-rolex-omega-tissot-2045-/111473300849?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item19f4539571
With timer..
http://www.ebay.co.uk/itm/Watch-cleaning-machine-janta-pearl-brand-with-timer-cleans-all-watches-2047-/291253631038?pt=UK_Jewellery_Watches_WatchAccessories_SpareParts_SM&hash=item43d011b83e
Janter Branded.
Edited by SSTEEL
I also have one of these elma cleaners, it seems that there is now a buzzing sounds and the switch doesnt really work, after long use there is a slight smell of burning. Im assuming i need to clean up the bearings in the motor and replace the switch.
I could probably figure out the switch,but wouldn't know how to clean up the motor bearings.
Any help would be appreciated.
Thanks
J
I wouldn't be over concerned about the bearings unless they are making a noise. The switch on the other hand will probably be what is making the buzzing sound. If you can't get the switch apart to clean the contacts, I recommend you get a new one sooner than later. In all honesty, you should replace the switch anyway.
Once you have replaced/repaired the switch, run the machine dry and hold the blade of a long screwdriver to the top and then bottom of the motor as close to the bearings as possible, and put your ear against the handle. You will be able to hear how good the bearings are. There should just be a gentle hiss, if they are screaming or rumbling, replace them.
Well my Elma Super Elite is coming together slowly, I have removed all the old paint from the circular base, heater chamber, and motor cover so far with the timer housing and front fascia, and central pole clamp currently soaking in acetone ready for the refinishing.
Base..
15648207765_907ecf80c9.jpgUntitled by Micky.!, on Flickr
Heater chamber, and motor shroud..
15678012071_882950fef3.jpgELMA SUPER ELITE REFURB by Micky.!, on Flickr
I have purchased what I think is the correct hammered blue paint, but I am actually now considering not painting it a colour at all, I might just clear coat it to give it that rustic look, undecided at the moment, so any opinions would be greatly appreciated.
Edited by SSTEEL
That's one hell of a thorough job your doing Micky, I'm looking forward to seeing the end result. Regarding finish, I think I would go with the blue hammered finish, I think it might be more durable and resistant to cleaning fluids.
Thats very useful info - thanks for sharing.
I am sure Graham Baxter uses powder coating when he referbs the L&R machines - is that an option for you?
I have never done powder coating so I don't know what is involved but I understand it is very durable.
Ideally Mark, I would love to have it powder coated, but alas I know of nowhere local that offers this, so what I done is found a very close match blue, with hammered effect, its brush on Hammerite.  I just hope I manage to achieve a nice even coating with it.
Edited by SSTEEL
    • I missed this earlier. The dial isn't going into the holder, it should sit proud of it. This is what I am currently using which I print for each different movement.
    • I didn't think pulling to set position would work harden the spring, in that position it is stressed where the arm starts. By work hardening i meant rapid polishing at that point, a bit like polishing a pivot work hardens as it compresses the steel. I doubt polishing by hand would achieve much in that respect though. Its finished, arm polished up mostly at the join to the bridge's main body. I'm ok with it, the screw holes aren't great as i had to open them up by redrilling and positioning it was difficult, I'm not much use with a loupe, opening up with a file might be a better option for me or i could just use the correct drill size 😅. And the detent is way too deep, i had to guess that with the stem release out of position and sat on top, but i only took one measure and went for it, no slowly slowly catch your monkey 😅. First go I'm happy , well sort of, it works and thats a big thing for me, next one will have a bit more finesse.  Anyone thats interested, after filing, i used a 2000 grade home made diamond  micro file and then 20 micron film, the film is much better than wet and dry, more stable to use and doesn't shed cheap grade grit everywhere , then auto polish on a sponge pad.
    • I'm assuming that every time you set the watch you are work hardening the detent spring, maximum hardening is  where it meets the plate due to maximum deflection.   That's why it snaps there.  The Young's modulus may be the same but after it's reached its maximum yeid strength it breaks.  My mechanic engineering is very rusty, correct me if I'm wrong.
    • Ah ok yes that makes sense to polish it where the arm starts to form from the body of the bridge, i thought you meant the underneath of all the arm.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
