Question about Swiss part numbers
I need to replace the date indicator driving wheel on a FHF 90.5. The part number is 2556. Cousins have most of the parts for this movement, but they have two date indicator driving wheels: one with the number 2556, listed as out-of-stock (obsolete), and one with the number 2556.1 (in stock). Unfortunately no pictures.
So what's the difference between 2556 and 2556.1? Which one do I need?
Hi    you could try comparisson sites, AG Thomas, Gleave and co, Dr Ranfft for tech details etc, Esslinger in the USA . Have a look on Cousins PDFs for the FHF 90.5 Tech sheet or Gleave & Co on their tech  hub for further information. All available on the web.
5 hours ago, saswatch88 said:
i wouldnt know but couldnt you call cousins and ask, they should know for sure
They have this policy:
"Due to the specialised nature of the industry and the variables with customer specific applications we are unable to provide individual technical advice on your requirements. Our website does provide all information to enable customers to identify and select their specific requirements.
If you need technical help we recommend you seek the assistance of a trade professional."
Not many clues in the usual places on this question, funny enough though, I note that Watchguy, Gleave and Cousins all have the same hand made annotation on their parts sheets!
Most likely they are interchangeable and the 2556.1 is just an upgraded version.
By the way, if your German is up to scratch, this might interest you. If not, then just the oiling charts might be of use http://forum.watch.ru/attachment.php?attachmentid=952077&d=1426676161
Could be that the 2556 is for the 90.5 and the 2556-1 is for the 905 . Have some 90.5 and 905 movement can have a look if i have the part.   On the one i found is a plastic part that i think would easily break. Don't know if it's a 2556 or a 2556.1
I had assumed that the 90.5 and the 905 where the same movement, just that some people forgot the dot!
Thanks for the service manual, I don't know any German but it's still useful.
The part I need to replace looks like the one in that manual- i.e. a smiley face.
Don't know why. But if you look at ranfft there is a 90-5 and a 905 . They look to be the same? But have seen both 90,5  and 905 printed on the bottom plate. So i guess maybe one of them is an updated version . http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&2&2uswk&FHF_90_5
UPDATE:
I bought the part (the 2556.1) and it is exactly the same as the original. (The movement is a FHF 905, not a 90.5).
Unfortunately it hasn't resolved the issue- seems to be something funny going on with the date jumper...
15 minutes ago, Barnaby said:
UPDATE:
What about the date jumper? Lost the little gear on the stem?
No, I already got a new one of those as it was missing when I opened up the watch.
It turns out the end of the date jumper spring was turned up slightly, and catching on the underneath of the date guard plate. This was stopping the date jumper from operating properly. I've trimmed the end of the spring and now everything works.
    • Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos.  Good luck with your journey to service your Grandfather's watch.   Nick
    • Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case.  Its an unusual curved rectangular case and crystal.  I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch.  The base of the crystal is also curved to match the case, rather than flat.  I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type.  In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved.   Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-).  I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners.  Any tips or alternate sources for this source of crystal. Many thanks
    • Getting more interesting this post, innit? Mikeplilk, Waggy. Impressed with your efforts. Makes mine look amateurish. Hey, that's what I am. Still, I have good results with the 'frog'. Apprentice test piece. Paper is from https://www.ebay.co.uk/itm/234602659940?var=534248554534   I am aware that the more I delve into the DIY, the more I am gaining understanding of watchmaking. Well, a little each time. Ross
    • Now, that's a bad boy watch! 🫡
    • High frequency day: 36000 bph.
