Hopalong Cassidy - NOS Replacement Strap
JerseyMo
No, I don't collect the vintage character watch series made by US Time and Timex.  But I have restored a number of them and typically the strap is missing or well worn.  Some had very distinct straps and trying to find a suitable replacement is not easy.  Ah but, what if you could find a NOS?  Not so easy to do and I thought I never come across one for the Hopalong Cassidy.
You know the one with the big buckle and metal tip.  Than I get in a huge NOS lot from a retired salesman and found this >>>>
Edited by JerseyMo
typo
  • 4 weeks later...
Some things are just meant to be and that strap had your name on it. Well done!
Is it just me but, somehow I feel a little sad when I have to separate the strap from an old watch that have been together for goodness knows how many years. I have just stood in front of the waste bin with the strap from a watch that has been worn to the point it had assumed the shape of the owners wrist. The fastening hole was elongated by many years of use. I felt genuinely guilty about letting it finally drop into the bin. I can’t help but think about the person who might have owned it, the places it has been and the stories it could tell. I think I must be getting more sentimental with age.
You could, of course, attempt to restore the strap. Some of the leather ones I've encountered did actually restore quite nicely.
I even re-stitched a couple of them. Others however are so badly worn that they are beyond hope.
1 hour ago, Davey57 said:
Yes I have rescued one or two, but some are so disgustingly ingrained with “stuff” I could not bring myself to use them.
yep, as with all straps and bands there can be some seriously funky stuff growing in there!
  • 2 years later...
I cant say I had no difficulties. I was ready with the one you can see on the pics once then i was checking its performance on the timing machine it looked brilliant so i tried to regulate it while i was working from home. Just a light touch with my tweezers reaching it over my computer.... my tweezers slipped and i literally destroyed the HS. I was so sick I could not revisit it for about two days. I sourced another HS and as far as I remember I also ruined the pin pallet while I tried to clean it so I had to source that too. (the pins were stuck in rodico and the rodico pulled one of them out when I tried to lift the fork up, i put the pin back but it was not tight enough anymore) You can buy ladies watches with M21 on eBay for about £2-£4 as a donor movement. I have serviced another M21 since this one and another two M22s are on my desk. Just like with anything else everything gets easier/quicker to handle if you practice it. Originally I could not even imagine how to put the main plate back and now I don't even consider it as a difficult task, it usually goes back all right for the first try.
Edited by luiazazrambo
11 hours ago, magic2020 said:
Got one just like that as a present in 1956  (I'm 75), but hesitant to do anything with it in case I fail miserably!
Maybe one day?
If you need advice or parts let me know I am going to try to help you the best I can. Take care.
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
