7750 service help
Is this the correct orientation for the chronograph cam? My first go was a fail so just want to check I’ve got everything in the right place before I proceed further
In one of marks videos he states that he has engaged the cam (given it a slight turn with his tweezers), so he can fit the chronograph runner wheel. I think this is what I’ve done?
On 4/4/2019 at 8:35 PM, HSL said:
Seems to be in place.. On the wrong device to see clearly but will upload a pic which you can compare with..
Thanks alot, as far as I can see I'm good to progress further.
On 4/4/2019 at 8:53 PM, watchweasol said:
Hi AP  there is a service document on cousins uk site I have loaded the pdf exploded diagram might be of some assistance for you
Thanks for the help, I do have those diagrams from eta. The cam orientation is totally different from the videos I've seen and also Lawsons tutorial, so not sure if it actually works in the position the diagram, which is odd.
The 7750 is quite straight forward to work with I add some pics which shows you what to look for and help you in the progress..
Good luck and keep up the good work!
You've confirmed a couple of things with those pictures, so thanks for taking the time to do this. Fingers crossed i'm going to get a chance to assemble it tomorrow, hopefully I can post a video of it working
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
