Question about removing cap jewel screws
saswatch88
hello WRT.
my inquiry is about removing cap jewel screws. I work on old watch movements, usually waltham and elgin 0size and smaller. and i swear i can never get cap jewels screws out, no matter what size screwdriver i use. Iam using top of the line bergeon tempered steel drivers. these csrews are so tiny and the slot is thin and shallow my blade just slips right out. you know when you think your turning the screw but your not. its so annoying and if i do manage to get them out its even worse trying to put them back in. This makes it very difficult for me to do a proper service so Iam wondering if anyone knows a specific driver or blade i should use.
the bergeon .6 and .8 i cant use because i need to apply pressure and with bergeon the blade shanks are the same with as the blade, so any pressure bends and/or breaks the shank. I was looking into getting a set that has wider shanks than the blade, like the old time drivers. i dont know why bergeon doesnt do it, iam guessing so you cant use their blades with other drivers. i have a cheap set that has wide shanks but the blades are garbage, i even tempered them and they still suck. any suggestions
Edited by saswatch88
Even worse is if the head pops off those tiny screw.
I found soaking parts in kerosene for a day or two even longer,  makes a world of difference and much more effective than penterating oil, WD-40 or any other solution of the sort.
Also screwdriver sharpener is a very useful tool, I shape the blade on a worn screw driver especially for the task.
If you remove the BW and adjust arm and place the cock on a flat strong anvil, you would have much more control over the operation. Good magnifiction also improves your control.
Combining all above, I have had no problem removing those tiny screws and with such ease.
i dont think its a matter of using penetrating oil to loosen screws its more the blade of the screwdriver not fitting properly in the slot. i know a cylinder will give me more torque but my main focus is having a blade that fits properly, obviously many pros use the bergeon drivers and they remove jewel screws but i just dont understand how. i need to somehow upload a video. these screws have such thin and shallow slots. it like the blade needs to have a knife edge to fit.
I use the 0,6 stainless steel blades and usually no problems getting them out. But get the harder stainless steel blades and cut the a little shorter so they won't bend. Some screws have a very thin slots  for the blade and they are hard to remove.
I agree with the comments above, I think the answer is to make sure your blades are properly dressed and snugly fit the slot. Suggest have a close look at the slot to see if it damaged or shallow as well. I use a very find ruby stone for dressing screwdriver blades. These stones are available from the usual sources.
Go well.
    • That's very interesting information. I haven't tried to see if my bombé jewel holes have olive holes but I think I should be able to tell on the larger jewels at least. See if I get a chance to have a look later today. This little story was very comforting to read for a "bungler" like myself. That success isn't a given even for a pro. Thanks for sharing!
    • I forgot that I said I would do that. Will take some tomorrow and post them up post haste.
    • I've seen some really nice early 20th century pieces where all the jewels, including center wheel, were convex. Definitely to reduce friction. It can be quite hard to tell if a jewel has olive holes, especially on small sizes, but that again reduces friction- as well as accommodates small misalignments better. Why they aren't used more often? I imagine it was found that at a certain point in the train the actual advantage became negligible, and the added cost on high production movements is why it's not seen on those, just higher-end pieces.   I did an experiment on a little 5x7"' AS 1012 a few years back. These things run OK sometimes, but often are absolute dogs. And AS made gajillions of them. I had a NOS novelty watch in for a service, ran OK flat, massive drop in amplitude vertical. Made like 3 staffs for it trying different pivot sizes, no change. Tried high quality (not Seitz) convex/olive jewels, no change- the original were flat, but could have been olive hole. Same for the pallet fork, then escape wheel, no change. Probably had 20 hours in the watch, new staff and new hole jewels through the escape wheel, no difference in running. Just a dog of a movement. But if I were making a watch I would use them, just because.
    • When Nicklesilver mentioned the use of them on non coned pivots on older high end watches closer to the escapement.  That suggested to me  probably fourth wheels and possibly third wheels. The square shoulder rotatating on the much smaller surface area of a dome as opposed to a flat jewel surface. I'm curious as to why they are not used predominantly?
    • That's what I thought, but as I said, it makes sense. See if any of our pros will have something to add.
