Old desk clock
philipk5
As part of my ongoing learning curve I am interested in finding out a bit more about the history of this clock. ( I hope the markings on the dial between the numbers are not Chinese characters!)
The movement winds and runs but the hands seem to be loose and have a mind of their own.  All in all a pretty clock (in my opinion)!
Thanks
There seems to be conflicting "information" when searching the net regarding when Le Coultre became Jaeger Le Coultre, and thus finding the latest date for my clock. There also seems to be no relevant info on Le Coultre and Sandoz, hence my posting on here.
I think it has always been a desk clock and not a framed pocket watch?
The overall size is 2 3/4 inches square.
Your clock appears to be a desk clock of the strut variety, it should have a fold out strut at the back for standing the clock up on a desk, A.lecoultre merged with Edmond Jaeger in 1937 becoming Jaeger lecoultre there after, although in some markets they still marketed clocks and watches under the Lecoultre name alone mostly in American markets.
Sandoz used various other names for watch production Tavannes, Cyma, being the best known, the link with lecoultre is that Sandoz supplied Calibres to other companys including Lecoultre, the first two years of production of Lecoultres most famous watch the Reverso used a Tavannes movement.
I would say that your clock would be from around the 1920's.
    • I would go for the dearer spring. You won't need to remove the spring from the carrier ring and then use a mainspring winder to get it into the barrel, for a start. Also that spring is closer to the needed dimensions, especially the length. The length plays a part in the mainsprings strength. If you double the length you will half the force (strength) of the spring and vice-versa. A spring with 20 mm less length would be about 7% shorter, so technically would be 7% more strength, but I find halving this number is closer to real-world findings, so the spring would be about 3 to 4% more strength/force. On a mainspring that ideally kicks out 300 degrees of amplitude, a 3% increase in amplitude would be 309 degrees. Increasing or decreasing the length of the mainspring will affect the power reserve to a greater or lesser degree. It depends how much shorter or longer it is.
    • I recently bought this but not on ebay. I figured if I want something Japanese I better check Japanese auction sites since these don't seem to pop up on ebay. I paid 83 € plus shipping & taxes. I think it was pretty reasonable for a complete set in good condition.
    • Did you take the friction pinion off the large driving wheel and grease it? Although, now that I think about it, that shouldn't have any effect on the free running of the train if the friction pinion isn't interacting withe minute wheel/setting wheel...
    • I did in fact use Rodico to get the spring into general position and "hold" it there while I used a fine oiler to make subtle positional adjustments.
    • The two measurements of particular importance wound be the height and the strength,  the length would obviously correspond with the increase/reduction of half mm of barrel diameter. There is a big difference in price considering that the more expensive one is the shortest. The longer one might be ok ? But then it is taking up more room in the barrel, might it effect the unwinding ? I wouldn't have thought so for just that small amount.  Ideally a pro might reduce the longer one to suit. But there is some information that might help, do you have the one that was fitted to measure up, though not necessarily the right one.
